1994 Honda Civic DX Coupe - Problems accelerating PLEASE READ - Honda-Tech
Old 07-25-2011, 09:03 PM   #1
Default 1994 Honda Civic DX Coupe - Problems accelerating PLEASE READ
Hello, Honda-Tech. I have a dilemma with my 1994 Honda Civic DX. I purchased it from a seller on Craigslist who, of course, said everything was great on it considering its age. I'm new to automobiles and have no real knowledge of them. Besides, the only car I've owned is a 1993 Toyota Camry (I know basics about repairing a Camry). But I'm totally new to Honda Civic. I checked the basics, for leaks, sealing problems, startup problems, knocking, and took it for a test drive. I desperately needed a car so I took the guy's word. It has 166,000 miles. On the way to drop the seller off, he was driving, I noticed he would take his foot off the gas, reapply pressure to the gas, and repeat. I asked him why he was doing this, saying was it because the gas was on E (the gas was all the way down, bad sign I didn't heed?). He said that was indeed the reason and I brushed it off as nothing. I'm here with that problem. Randomly while driving, the car WILL NOT accelerate past 10, 20, or 30 mph. What does that mean? No matter how much pressure I put on the gas, it simply will not accelerate. In order for it to get past the speeds it won't get past, I have to do what the seller did, take my foot of the gas then reapply pressure repeatedly. My dad lives in a different state as I'm going to college this upcoming semester, so he couldn't come with me when I bought the car to check it out. He thinks it's something wrong with the throttle or fuel injectors or something. I don't know much of anything about cars, guys. So, can someone please explain to me in laymen terms my problem? Thanks for reading and your concern, Honda-Tech.
ataplin777 is offline   Reply With Quote
Old 07-25-2011, 09:12 PM   #2
Default Re: 1994 Honda Civic DX Coupe - Problems accelerating PLEASE READ
Click on the CEL sticky to learn how to check for CEL codes.
Does the CEL stay on or turn off after 2 seconds when the key is turned from off to ON(II)? Or does it never turn on?
Former User is offline   Reply With Quote
Old 07-26-2011, 07:04 AM   #3
Hey, thanks for responding. I would check now but my mother uses my car for work and will be gone all day even though I warned her against putting all those miles on it when I don't know the problem. I'll have to post the answer to that question tonight.
Old 07-30-2011, 12:42 PM   #4
Ok I've read the sticky and did the method with a paper clip but the light doesn't flash. In regards to your question, the CEL goes off after two seconds.
Old 07-30-2011, 02:34 PM   #5
There are no codes currently stored in the ECU. If the CEL turns on while driving, pull over and leave the engine running while you jump the service connector.
Old 07-30-2011, 06:55 PM   #6
Ok, will do. Thanks.
Old 07-31-2011, 02:13 AM   #7
92bseries's Avatar
just sounds like its a tps problem. i had problems with that damn sensor once and i had to drive my car home doin like 20 and when it hit the max position the car would fal on its face unless i let off the gas so it wouldnt keep sputtering. but i could be wrong. might want to check cel's like stated and if you get nothing from that, id try to adjust the tps or get a new gasket for it and then re-adjust.
92bseries is offline   Reply With Quote
Old 07-31-2011, 05:25 AM   #8
foo fighters's Avatar
Fuel filter???
foo fighters is offline   Reply With Quote
Old 07-31-2011, 02:50 PM   #9
Quote:
I do think it is a tps problem. That's what makes the most sense in my opinion. I haven't driven it a lot since it last had problems because I wanted to get it checked out by a mechanic, I'll be doing that Monday if everything goes according to plan.
Test drove '06 S2000 - found issues with excessive torque steer/pulling - advice? VTEConly Honda S2000 12 04-03-2007 07:01 AM
Please Help! Turbo Problems... Toyosrus Forced Induction 6 12-11-2006 10:27 PM
Intermittent hesitation/shudder on my friend's Camry...what could it be? erikiksaz1 General Discussion and Debate 3 02-25-2006 08:14 PM
hesitation and acceleration issues - 1993 Automatic DX coupe INVALID Tech / Misc 0 03-19-2005 04:14 PM
Shifting Technique thread, good info. mnbv Road Racing / Autocross & Time Attack 17 10-02-2004 03:55 PM
Tags
20, 2002, 94, accelerate, accelerating, camry, car, civic, craigslist, dx, gas, honda, mph, past, problem, trouble, wont, wontaccelerate
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
