1992 Civic brake pedal sometime goes to floor
Old 06-09-2011, 11:23 AM
T_ypEr's Avatar
Icon6 1992 Civic brake pedal sometime goes to floor
I have a 92 Civic that has a bit of a brake problem. This is my girlfriend's car and my dad and I helped her get it and put it back on the road. When we did the brakes we bled them 3 times (in the correct sequence) and they felt great. A few days after my gf got the car the problem started (almost a month ago). What happens is she'll be driving along with the brakes working fine and then one time the pedal has to go almost all the way to the floor for the same braking power as the last time she pressed the brake pedal. Then the next time they go back go normal. Any ideas what it could be? We already ruled out a leak because there are no traces of brake fluid under the car or behind the wheels. Plus, her brake fluid resevoir is full.
Old 06-09-2011, 11:58 AM
chope045's Avatar
Default Re: 1992 Civic brake pedal sometime goes to floor
change the mater cyclander my eg was doing the same thing replaced it and had no problems
Old 06-09-2011, 12:17 PM
SpecialK_4182's Avatar
Bingo.
Old 06-09-2011, 12:21 PM
Linked's Avatar
reason being is because when the seals begin to wear out in the MC and cannot hold pressure at times, the intermittent pressure lost is one of the symptoms
Old 06-09-2011, 05:50 PM
T_ypEr's Avatar
That's making sense so far..... Is there any other possible problem that it could be?
Old 06-09-2011, 06:01 PM
Linked's Avatar
unless your LOSING fluid either at the wheels or behind the brake pedal
the worn seals inside the MC is the most probable cause
Old 06-09-2011, 06:04 PM
redm3turbo's Avatar
If you bled em right...
M/C .
Old 06-09-2011, 06:14 PM
vitamin_c95's Avatar
master cyl
Old 06-10-2011, 05:51 AM
#1 Super Guy
94eg!'s Avatar
Yes, it's an internal leak within the master cylinder. I've personally experienced this 3 times now (on 3 different cars). It usually begins to act up when it gets hot out.
On one of the cars, I could actually watch the reservoir rise and fall as the pedal was pushed to the floor and let out again.
Good luck...
Old 06-16-2011, 09:35 AM
chope045's Avatar
[QUOTE=94eg!;45436772]Yes, it's an internal leak within the master cylinder. I've personally experienced this 3 times now (on 3 different cars). It usually begins to act up when it gets hot out
every honda that my friends had that had brake problems stoped once the m/c was replaced
Old 06-16-2011, 11:57 AM
T_ypEr's Avatar
Thanks for all the replies! It was the Master Cylinder and we replaced it with a new one.
Old 06-16-2011, 02:35 PM
#1 Super Guy
94eg!'s Avatar
This is the nice part about a hydraulic failure. They tend to be noticeable, but gradual. This gives warning without killing you...
da1lydr1ver
03-26-2012 06:25 PM
about:blank
05-28-2008 08:21 AM
ThagAnderson
06-28-2007 12:41 PM
j92civic
01-21-2006 08:33 PM
dnt94civic
06-07-2002 05:04 AM
Quick Reply: 1992 Civic brake pedal sometime goes to floor
