compatible ECUs for LSvtec
Risky Business
Re: compatible ECUs for LSvtec (WiDeBoDyEK)
are you doing OBD-II or OBD-I?
My friend has OBD-II LSVTEC and switches between a P73 ITR ECU and a P2T 99 Si ECU...the ITR ECU has a permanent check engine light because the immobilizer had to be removed when it was taken out of the original car.
Re: compatible ECUs for LSvtec (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">are you doing OBD-II or OBD-I?
My friend has OBD-II LSVTEC and switches between a P73 ITR ECU and a P2T 99 Si ECU...the ITR ECU has a permanent check engine light because the immobilizer had to be removed when it was taken out of the original car.</TD></TR></TABLE>
the LSvtec motor is not mine,..im asking for a friend because with my old LSvtec motor,..i used a chipped p28,...he has a 99 LS motor with a 99 SI head (so in other words OBD-II ),..he just asked me if he could use his 99 SI ecu,...so just to clarify,..you are saying YES he can use his 99 SI ecu?
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WiDeBoDyEK »</TD></TR><TR><TD CLASS="quote">
he just asked me if he could use his 99 SI ecu,...so just to clarify,..you are saying YES he can use his 99 SI ecu?</TD></TR></TABLE>
yep
yep
yep </TD></TR></TABLE>
gracias
gracias
