14mm AC Tensioner Pulley Bolt Stripped. Best Way To Get It Off? - Honda-Tech
Old 08-02-2008, 08:10 PM   #1
Panoply's Avatar
Default 14mm AC Tensioner Pulley Bolt Stripped. Best Way To Get It Off?
as the title says, trying to do a timing belt change on a 93 civic dx and the damn bolt is giving me hell. before the bolt was stripped i tried using a torch to heat the bolt up, but to no avail it stripped on me before i could get it off. at this point ive even tried vice grips/heat but not luck. can anyone suggest the best way to get this off? the worst part is the tight space to work in. so please keep suggestions with that in mind. thanks.
Panoply is offline   Reply With Quote
Old 08-02-2008, 08:28 PM   #2
Default Re: 14mm AC Tensioner Pulley Bolt Stripped. Best Way To Get It Off? (Panoply)
take a smaller sized socket and bash it on there.
or
weld a socket to it and crank it off.
worst case scenario, you have to drill it and use an extractor.
AtomicBlast is offline   Reply With Quote
Old 08-02-2008, 08:40 PM   #3
craftsman has a set of stripped bolt removers for like 15.00 i think thats what i paid for them. you can get them at sears. i had the same prob with my car. plus they come in handy.
yurevn is offline   Reply With Quote
Old 08-02-2008, 11:12 PM   #4
Panoply's Avatar
Default Re: 14mm AC Tensioner Pulley Bolt Stripped. Best Way To Get It Off? (AtomicBlast)
Quote:
or
if i got a socket on it, i wouldn't be able to get the rachet on it. the bolt is <2in away from the side of the car
Quote:
does it require that you use a rachet to turn the bit?
thanks for the help so far
Old 08-02-2008, 11:18 PM   #5
AnotherSI's Avatar
did ya try supportin the engine with a jack and takin off the motor mount and letting the engine down or crankin it up alittle to get alittle more access?
AnotherSI is offline   Reply With Quote
Old 08-02-2008, 11:20 PM   #6
Panoply's Avatar
Default Re: 14mm AC Tensioner Pulley Bolt Stripped. Best Way To Get It Off? (AnotherSI)
yeah, didn't seem like i gained too much room. maybe if i disconnected the rear mount i could get a few more inches.
Old 08-03-2008, 05:00 AM   #7
mistaashby12's Avatar
strap a bomb to that b!tch. cause by this point I know you want to!
haha
ok seriously can u reach it with a deep well?
if not you can take 2 sockets, cut one in half weld back together to make a double length socket.
make sure u use a 12pt socket that is just a little bit to small.. and hammer or tac weld it on
Im not quite sure if I am imagining your cramped quaters your in, but if u have room this will work like a charm
ninja speed my friend
mistaashby12 is offline   Reply With Quote
Old 08-03-2008, 11:03 AM   #8
no you can use a wrench. thats what i did.
Old 08-03-2008, 05:13 PM   #9
Panoply's Avatar
Default Re: 14mm AC Tensioner Pulley Bolt Stripped. Best Way To Get It Off? (yurevn)
i went and picked a set up this morning and they worked fantastic. i liked how they were low profile so they were very easy to work with. thanks everyone for all the suggestions.
thermostat housing issue Bigrome34 Honda Civic / Del Sol (1992 - 2000) 6 06-20-2010 12:08 PM
Lower radiator hose cold, no heat , overheating 93grayeg Tech / Misc 9 01-19-2010 09:41 AM
removing rusted front brake rotor - 92 prelude giddyup21 Honda Prelude 23 05-15-2007 03:29 PM
stripped bolt..help!!! MI4$DC5 Honda Civic / Del Sol (1992 - 2000) 5 12-21-2005 07:24 PM
trying to replace exhaust on friends dsm...bolt from piping to muffler stripped! threatcon13 General Discussion and Debate 1 05-11-2002 06:59 PM
Tags
02, 93, ac, acura, bolt, civic, honda, integra, odyssey, pulley, rsxs, stripped, tensioner, tire, tool
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
