1 wire to 4 wire oxygen sensor
I have a CX with a 1 wire o2, and i bought a GSR swap that came with the wire harness. Now can i just use the GSR wire harness and not have to wire anything into the ECU as far as the o2 goes ?
Re: 1 wire to 4 wire oxygen sensor (Jmunk)
im pretty sure for obdI you can use the gsr harness and the only thing you have to worry about is vtec as far as wiring goes.
Anyone else ? I can't see Honda using a "special" harness for the CX to go to the ECU from the shock tower. I would think that from the shock tower to the ECU would be the same harness for all the models.
Re: (Jmunk)
i swapped a d16z6 into my cx with a cx engine wire harness. i wired all the non vtec wires (o2 wires) right to the shock towers. if i had a d16z6 engine wire wire harness the only wires i would have to worry about would be vtec.
Fuster_Cluck
04-10-2003 05:40 PM
