Looking to get a civic
Old 01-16-2010, 01:03 PM
New User
Vaspyder's Avatar
Default Looking to get a civic
As the title says, I am thinking about getting into a civic. I have a wrx now, and got an offer for a built civic, just wondering if you guys could help me figure out if it is worth looking into more.
Here is the mod list:
1994 civic coupe ls-vtec turbo CLEAN TITLE
Car is an EX so it has Power Windows, Door Locks, Sunroof, And Mirrors, has 1000 miles on it since build and boy it runs strong. This car has good paint I’d say 7/10. I have over 9000$ in receipts legitimately you can take a look for yourself. Every part on this car engine wise has 1000 miles on it no joke, no bull, including the tranny its been opened up had all the synchros resharpened and 2 replaced.
SUSPENSION:
Skunk2 Lower Control Arms GOLD
ASR Subframe Brace POLISHED
GSR rear disk (calipers painted the right way RED)
Type R Sway Bar with Spherical Endlinks
Skunk2 Pro S coilovers
Brake pads have about 2k on em
Skunk2 Rear Camber Kit
OBX Front Camber Kit
APR Front strut bar hella chunky
Cross Drilled and Slotted Rotors Front and Rear
ENGINE:
Chipped and Tuned P28 ECU…Made 336hp 210trq on 11ps. this engine will see close to 450hp on 14-15psi with 750cc,
B18A Block 81.5MM, fresh bore and hone
GSR Hydraulic Transmission with fresh rebuild
B18C GSR Head
GSR Cams
GSR Water Pump
Eagle H Beam Forged Rods with ARP Rod Bolts
Cometic 3 layer head gasket
JE Pistons 9:1 Low Compression, With brand new rings
T3/T4 Ebay turbo however this turbo has been rebuilt professionally and also has only 500 miles on it come see for yourself
New Tial 38mm Wastegate (SILVER) with new gaskets
3’’ Stainless Steel Downpipe with Flex Pipe and Dumptube Custom fabbed by Ricky of SPEEDFACTORY
3’’ TURBO-Back exhaust Custom from SPEEDFACTORY
2.5’’ Intercooler Piping
Huge 600hp Spoon Sports intercooler
Misimoto Aluminum Radiator with SlimFAN
Brand New Aeroquip Turbo Return line
New Turbo Inlet Metal Gasket
BLOX Manual Boost Controller
SPEEDFACTORY 4 Bar MAP Sensor
HKS SSQ Blow Off Valve Version 3 (the brand new one that came out)
AEM Fuel Rail
Cant remember the name but name Brand Fuel Pressure Regulator with Gauge
450cc DSM INJECTORS
Walbro 255lph Fuel Pump With Upgraded Fuel Pump Wiring and Inline Relay
ACT Pro-lite Flywheel 8.8 lbs
Golden eagle VTEC CONVERSION
Micro-polished and balanced crank
ACL Race Main Bearings with extra clearance for more oil
ACL Race Rod Bearings
ACL Thrust Washers
SPA topmount turbo manifold
Supertech Dual Valve Springs
Supertech Titanium Retainers
Head has New 3 way grind
Brand new valve stem seals on both exhaust and intake side
Omnipower Flat face valves for both exhaust and intake sides
Edelbrock Victor X intake manifold
Innovative Motor Mounts POLY
Competition Stage 4 Clutch
Type R oil pump
New OEM oil pan gasket
Brand new rear main seal
New oil pump gasket AND seal
New GSR Timing Belt
New OEM thermostat
New thermostat Gasket
New water pipe O-ring
New VTEC Dowel o ring
THERMAL REUSABLE intake manifold gasket
BLOX BLUE camshaft seal
BLOX 68MM Throttle BODY with New Gasket
NGK Sparkplug wires
NGK BKR7E Spark plugs
New Distributor Cap
Type R Throttle Cable and Type R cable Bracket
Golden Eagle Headstuds
Odyssey Performance battery (military grade) relocated near tranny with custom bracket
…………..im probably forgetting something but you get the jist
INTERIOR/EXTERIOR:
2 way Compustar ALARM SYSTEM with TURBO TIMER
Black S2000 seats
Skunk2 Weighted Shift ****
ALL Four Mudflaps in GOOD condition
JDM Window Visors
CTR 5 piece Floor mat set, if bought you will get the minty stock civic mats
Phantom Boost Gauge, lights up RED, single pod, no ricer triple stack pod
Nice *** Alpine Deck with IPOD hook up, and wired for subs
Pioneer Speakers in the rear and up front, sound pretty nice even without bass
JDM red/clear taillights
HID headlights ICEBURG color I think they’re deep blue
15in white slipstreams 195/50/15 75% Tread
OEM civic ex front lip
10in JL audio 1000 watt sub with 400 watt amp
NRG short hub
NRG quick release
Momo tuner steering wheel
The car is totally reliable. it passed emmissions first time. hard to belive, i know. but i also will throw in the old turbo kit that was on the car. along with a alpine indash to come withh the car. like i said i have every reciept totalling over 9k along with the dyno sheet. so you can look for your self. heres a few pics if u want more just let me know. thanks. rims were green but can are now white
Thanks!
Old 01-16-2010, 01:13 PM
ReVeNgEd-SoN's Avatar
Default Re: Looking to get a civic
I don't see any pictures :S
But from the mods, it seems like a good deal for 9k.
Old 01-17-2010, 01:12 AM
onlyJDM95's Avatar
Pictures?
Old 01-17-2010, 05:24 AM
95_Civic_4dr's Avatar
What's wrong with the WRX? Reason I'm asking is I was actually thinking of leaving the Honda scene and leaning more towards an STi or EVO MR. Can't say you'd be disappointed with a Civic though, just be careful where you leave it, don't want your **** gettin jacked by some lazy dumbass.
I see no pictures O.O
Natedawg241
Southeast (Sales)
02-13-2010 05:47 AM
b16_powered_si
03-27-2009 08:39 PM
deftones0817
09-03-2002 01:50 PM
Quick Reply: Looking to get a civic
