Is 1/2 inch of throw on slave cylinder enough? my clutch is dragging - Honda-Tech
Old 09-14-2012, 09:07 AM   #1
themow's Avatar
Default Is 1/2 inch of throw on slave cylinder enough? my clutch is dragging
My clutch is dragging and I want to make sure its not a hydraulic issue before i replace the clutch. I replaced the slave last night its still dragging and hard to get into gear when stopped. My slave travels 1/2 inch total from when the pedal is completely up to completely floored. If it should be more like an inch, I will replace the master. Thanks
themow is offline   Reply With Quote
Old 09-14-2012, 09:17 AM   #2
I'm not Rick!
rick_rabies's Avatar
Default Re: Is 1/2 inch of throw on slave cylinder enough? my clutch is dragging
is the fluid bled properly? any leaks in the master?
how old is the clutch?
rick_rabies is offline   Reply With Quote
Old 09-15-2012, 04:32 AM   #3
themow's Avatar
Its bled, there are no leaks, and the clutch is original. 220 k. No slipping catches strong.
Old 09-16-2012, 07:53 AM   #4
BUMP
themow12 is offline   Reply With Quote
Old 09-16-2012, 08:03 AM   #5
axis11's Avatar
Adjust clutch pedal to increase its travel. Have somebody watch the slave cylinder while you kick it from inside to see how much travel the push rod makes. Try to move the fork by hand to see it has more play in it. Usually the fork's pivot point gets damaged causing excessive play.
axis11 is offline   Reply With Quote
Old 09-16-2012, 08:51 AM   #6
yeah travel should be around 3/4", look under the dash at the clutch master cylinder look at its rubber boot area check that for leaks if it looks dry... make sure you have the clutch bled good, the best ways is with 2 people. and if your problem still remains i would think that the flywheel or clutch disc may be warped, causing it to not want to completely disengage
autospeed060 is offline   Reply With Quote
HOW TO: Diagnosing Stuck Clutch Pedal b20vteg757 Tech / Misc 5 06-26-2015 02:35 PM
clutch problem!! cnrdb8 Transmission & Drivetrain 2 10-12-2012 07:31 PM
Clutch fork / Slave cylinder / clutch install question. PLEASE HELP! EnjoyTheRideDC2 Honda Civic / Del Sol (1992 - 2000) 5 02-13-2007 01:38 PM
tranny not going into gear (just replaced slave and master cylinder) WAHTS WRONG!!!?? r1de4life Acura Integra 14 11-19-2006 07:36 AM
ITR Having big probelms with my slave cylinder Nerv2g Tech / Misc 1 07-09-2003 07:41 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
