04 DX SPEEDO INTO 97 DX
Make sure you get the plugs and about a foot of wire for the speedo cluster you buy. It's useless without the plugs!
New speedo requires trimming for proper fitment. I will post a couple of pictures and a diagram of what to cut when I'm allowed to post inserts again.
04 CIVIC DX INTO 97 DX SPEEDOMETER WIRE COLORS & DESCRIPTIONS
04 CIVIC DX 97 CIVIC DX
GREEN PLUG CONNECTOR A
A15 YEL POWER YEL (YEL PLUG A5 & BLU E4)
A4 BLU/WHT SPEEDOMETER BLU/WHT (BLU PLUG D11)
A16 WHT/RED IGNITION POWER BLK/WHT (BLU PLUG D15)
A14 RED/BLK HEADLIGHTS ON RED/BLK (BLU PLUG E13)
A11 BLK GROUND BLK (YEL PLUG A5)
A22 GRN/YEL RIGHT TURN SIGNAL GRN/YEL (BLU PLUG D4)
A9 PNK SRS (AIRBAGS) BLU (YEL PLUG A1)
A3 BLU TACHOMETER BLU (BLU PLUG E8)
A5 WHT/GRN CHARGING SYSTEM WHT/BLU (BLU PLUG D16)
LIGHT BLUE PLUG CONNECTOR B
B4 YEL/RED LOW OIL PRESSURE YEL/RED (BLU PLUG E3)
B3 GRN/ORG CHECK ENGINE GRN/ORG (BLU PLUG E5)
B13 YEL/BLK FUEL GAUGE YEL/BLK (BLU PLUG D10)
B11 BLK GROUND BLK (BLU PLUG D2)
B9 RED/BLU SEAT BELT REMINDER RED/BLU (BLU PLUG D6)
B8 GRN/RED LEFT TURN SIGNAL GRN/RED (BLU PLUG E7)
B12 RED DASH LIGHTS BRIGHTNESS RED (BLU PLUG E12)
B10 RED/YEL HIGH BEAM INDICATOR RED/GRN (BLU PLUG E6)
04 SPEEDOMETER
GREEN PLUG 22 PIN CONNECTOR A
LIGHT BLUE PLUG 22 PIN CONNECTOR B
97 DX CAR
YELLOW PLUG 5 PIN CONNECTOR A
LIGHT BLUE PLUG 16 PIN CONNECTOR D
LIGHT BLUE PLUG 13 PIN CONNECTOR E
04 SPEEDOMETER
97 DX CAR
Re: 04 DX SPEEDO INTO 97 DX
I'm obviously not very good at posts. This is suppose to be info for those who want to follow. When I posted this it had "tab spaces" in between for clarity but the posting software deleted the tabs so it looks like run-on sentences. I'm being punished for being a smart *** and I can't do "inserts" of any kind so I thought I would post it anyway.
Why would you want to do this with a DX cluster? I hate mine. I was looking for an LX or EX when mine went out, but went with the DX because I'm cheap and the car was free.
The 04 dx has a tach and the backlit color is BLUE because it came from a sedan. I much prefer blue over Red which I think is much nicer looking. The Lx cluster is for Automatic's only and I have a stick.
Trihawker
11-14-2016 08:39 PM
boosted_zc
08-06-2005 10:02 PM
