00 civic si, Fuel Filter banjo bolt torque value?
Old 12-28-2008, 03:47 PM
DMCCOY's Avatar
Default 00 civic si, Fuel Filter banjo bolt torque value?
My service manual left out the torque value for the 17mm top banjo bolt on the Fuel filter and the torque value for the bottom as well. Would somone please post up the torque values? The manual says to check the values in the specs at the front...but they are not listed.
Old 12-28-2008, 03:49 PM
jfruauff's Avatar
Default Re: 00 civic si, Fuel Filter banjo bolt torque value?
just tighten it with a wrench as tight as you can.
Old 12-28-2008, 03:51 PM
Hanmin's Avatar
just until the crush washers are tight. just not overly tighten, just until you feel it not turning anymore when you turn the wrench lightly, then add a little jerk.. I don't have my book here, so I can't check for you.
Old 12-28-2008, 05:00 PM
Blown90hatcH's Avatar
27 lbf-ft
Old 12-28-2008, 05:12 PM
Inliner's Avatar
until it doesnt leak...
Old 12-28-2008, 05:59 PM
DMCCOY's Avatar
Thanks Blown90Hatch.
Old 01-31-2024, 07:29 AM
Butwh's Avatar
Originally Posted by Blown90hatcH
27 lbf-ft
Would the torque for the fuel filter banjo bolt on a 2000 Honda CR-V be 27 ft lbs?
Old 01-31-2024, 08:48 AM
spAdam's Avatar
Same filter, so yes. Generally you can do it by feel... torque until you feel the washers crush fully. Never just go 'as tight as you can go' on any fastener.
Make sure you use a wrench on the filter as well so that you don't transmit the torque through the filter and bend the bracket.
Old 01-31-2024, 11:15 AM
Butwh's Avatar
I have to torque things. I have absolutely no feel for tight. I've lost 3/4 of my strength in the last several years. I torque everything.
I've also been hosed by the ugga duggs crowd, by both over and under torqued stuff.
One resulted in engine failure - though - if my granddaughter had shut down the Suburban when the engine light came on, there would not have been much of an issue.
turboxsi
01-31-2024 07:25 AM
richboi
14
04-20-2006 07:17 PM
sol4redline
04-12-2005 06:08 PM
sol4redline
04-12-2005 03:52 PM
carbonDelSol
05-25-2004 01:43 PM
Quick Reply: 00 civic si, Fuel Filter banjo bolt torque value?
