No start condition after stupid attempted starts without basemap- what can I do?
I got my basemap in from Xenocron tuning. We tried starting the car with no basemap and no turbo before sending the ECU out, and I think I've flooded it. Spark plugs are black which indicates spark (I think?), I'm definitely getting fuel, probably too much. Would there be any reason why I wouldn't be getting air? Or lack of compression? When I crank it, it sounds "lumpy" and isn't the constant "click click click", more like "click.. click click... click click...".
Should I try jumping the battery?
Edit: Attempted jumping the battery with my van, it'll crank normally until the battery light turns on, then it'll sound uneven and lumpy again. It's not flooded, I disconnected the injectors and cranked until there was no smoke (bad I know).
I really don't know what to do.
Re: No start condition after stupid attempted starts without basemap- what can I do?
Charge the battery with an AC powered charger to bring it to full capacity.
Plugs with a lot of black stuff on them could be "fouled out" and not spark well or at all. Try new plugs, or put your plugs in a car that works, start it up if it will and take a short drive to burn the stuff off.
Compression test is always a good idea if you don't know the condition of the engine. If the valves are too tight you may have no compression in one or more cylinders leading to "lumpy" turnover and difficult or no starting.
We cleaned the plugs when they were out today so they're not very dirty at all, they're brand new as well. I had good compression prior to turbo install.
Started today! for 5 seconds, then it flooded out. Good thing I ordered a FPR, I think that'll fix the issue (wayyy too much fuel). Checked ignition timing, vacuum lines, and sensor clips, and hooked up compression tester. It wanted to start with the tester in, so we threw in the spark plug and she went until sputtering out.
For a compression test, first you would take all the spark plugs out so the engine will spin faster.
Then disable the ignition by unplugging the harness plugs from the distributor. That is very important on a Civic because the coil is prone to blow if you fire it into an open circuit (spark wire(s) unplugged).
Unplugging the distributor also prevents any fuel from being injected because without pulses from the distributor, the ECU thinks the engine is not turning.
Tested fuel pressure today, 50 PSI when cranking. I think this is my issue. I know FP would lower when the car is running with a vacuum signal, but 50 is way high. Good thing new FPR is coming tomorrow. Sound like it might be the issue to you? Would make sense since we checked literally everything else.
Katie Vanaman
Honda Civic (2006 - 2015)
04-11-2017 08:14 PM
civic92si
03-29-2007 08:28 PM
