00 Civic Lx - Acceleration stutter, pulsating interiors lights
Old 11-04-2016, 02:43 PM
HeresOtis's Avatar
Default 00 Civic Lx - Acceleration stutter, pulsating interiors lights
Hello all,
​​​​​​I have two problems (might be independent of one another). One problem is that my car starts to slightly jerk/stutter when accelerating from a complete stop. So it does it only in first gear. This issue only started occurring after I cleaned my battery terminals from corrosion and removed the paint from all my ground connections.
The other problem is that my interior lights and headlights pulsate for several seconds to a minute and at the same time, the SRS indicator turns on for 5 second then back off. This issue is ongoing success I first purchased the car. I checked my battery and alternator voltages and they are correct: ~12.8V while engine off, ~14.2V with engine on. To add on, whether the lights are pulsating or not, more frequently I've noticed that my interior lights get brighter after I drive over 2500rpm and when I have to come to a stop, they get dim (or normal brightness level?).
Can anyone give me some guidance on troubleshooting these issues?
Update: https://honda-tech.com/forums/honda-.../#post51111623
2000 Civic LX Stock everything
Old 11-04-2016, 04:39 PM
Former User's Avatar
Default Re: 00 Civic Lx - Acceleration stutter, pulsating interiors lights
Check fuse 15 and the alternator.
Old 11-04-2016, 07:38 PM
HeresOtis's Avatar
Just checked the fuse and alternator, and both are fine.
Originally Posted by HeresOtis
Just checked the fuse, and it's fine.
​​​​​​​Details?
Old 11-04-2016, 07:42 PM
HeresOtis's Avatar
​​​​​​​Details?
The fuse has continuity. The alternator is outputting the correct voltage which is about 14.6V. ​​​​​​​
Old 11-04-2016, 07:44 PM
What's the voltage reading when the interior lights are pulsing?
Old 11-04-2016, 08:09 PM
HeresOtis's Avatar
I'm unable to get that reading because it usually only pulsates when driving. I suppose it could be loose wires.
Old 11-04-2016, 08:10 PM
What interior lights pulse? Does the cluster charging system warning light also flicker?
You can connect the multimeter probes to a hot wire and ground under the dash to read voltage while driving.
Old 11-04-2016, 08:14 PM
HeresOtis's Avatar
What interior lights pulse? Does the cluster charging warning light also flicker?
​​​​​​​I would assume all lights which include cluster, lights in console, dome light, lights inside gear stick.
Old 11-04-2016, 08:16 PM
Without assuming, what lights have you observed to pulse?
Old 11-04-2016, 08:20 PM
HeresOtis's Avatar
When I say assume, I'm assuming that the lights I have mentioned are all the interior lights. Sorry for the confusion.
But yes, those are all the lights I've visually seen pulsate.
Old 11-04-2016, 08:23 PM
Does the cluster charging system warning light also flicker on?
Old 11-04-2016, 08:44 PM
HeresOtis's Avatar
The cluster charging light does/is not on.
​I don't see any open hot wire under dash.
Old 11-06-2016, 01:40 PM
HeresOtis's Avatar
I checked my TPS and determined that it's malfunctioned. More than likely, replacing will fix my stuttering issue.
I also checked my some of my wires to make sure there's clean connections. I'll update on how things go.
Old 11-07-2016, 01:05 PM
HeresOtis's Avatar
Another update: I was checking continuity of fuse 15 and encountered something interesting. While the engine is off, my multimeter outputs continuous sound to indicate continuity. But when I turn the engine on and check again, the continuity sound is now in quick pulses (beep, no sound, beep, no sound, ...). Any ideas?
Old 11-07-2016, 03:18 PM
mk378's Avatar
That is not how you test a fuse. The result also suggests the fuse may be blown.
Turn the key on (no need to start) and measure the voltage from each end of the fuse to ground. It should be about 12 volts in both cases. If there is low or zero volts on one end and battery voltage on the other, the fuse is blown. Confirm by pulling fuse out of the box, then test the fuse for continuity or visually examine the U or Z shaped metal link in the middle of the fuse.
While you have the key on with engine not running, the "battery" light on the dash should be on, and it should go out after starting the engine. I don't think it ever comes on if fuse 15 is blown.
Old 11-13-2016, 04:28 PM
HeresOtis's Avatar
Update in regards to the lights.
I verified that my instrument panel lights get brighter when either the car reaches 2800RPM or when the car is past second gear. But IDK if the lights are getting bright or "over-brighten" because they get as bright as if you turn the headlights off. To make it clearer, the brightness of the instrument panel when car passes 2800RPM gets to the same brighten as the instrument panel when the headlights are off.
Then when they car gets below 1500RPM (enters idle RPM?), the lights return "normal" or dim. I've checked all my grounds and made sure no wires were open.
Any more guidance?
Old 03-24-2017, 08:40 AM
Grumpy pigeon's Avatar
Hey I'm having a problem with my civic 2001 ex headlights and dash dimming while accelerating I have replaced alternator done big 3 4 guage replaced battery terminals wire brushed fuse box main connections checked battery around 12.4 off and 14.25 while running no idea what could cause it
Old 03-24-2017, 08:42 AM
Ps how do I start threads it's says I need two post in tech section idk what that is and don't wanna just post in unrelated threads
justinwebb
03-09-2009 11:45 AM
Puro Zacatecas
11-27-2008 05:33 PM
ezol
Honda Civic (2001 - 2005)
04-04-2008 03:56 PM
KevinT707
02-06-2004 03:41 PM
Quick Reply: 00 Civic Lx - Acceleration stutter, pulsating interiors lights
