00 civic ex heater smells terrible.
Old 01-24-2011, 08:33 AM
Woody.'s Avatar
Default 00 civic ex heater smells terrible.
Title says it all really
Doesn't smell burnt. Smells like... Crap literally.
Any ideas?
Old 01-24-2011, 08:49 AM
Kimbo's Avatar
Default Re: 00 civic ex heater smells terrible.
You have to clean out the core underneath the dash behind the glove box. It's all the mildew build up. This is in the Evaporator box.
Old 01-24-2011, 08:58 AM
itsnotfast's Avatar
Could be a dead rodent or mildew as the previous guy said. It could be anywhere in the duct work. Start hunting, and good luck to you sir.
Old 01-24-2011, 09:08 AM
Woody.'s Avatar
Do I have to take out the dash?
Old 01-24-2011, 09:38 AM
Dontoh's Avatar
ya. lemme find a good diy for it
about half way down for the dash removal
http://importnut.net/civicsteeringswap.htm
this has a little more info on your box
http://www.team-integra.net/forum/di...TopicID=273190
Old 01-24-2011, 09:52 AM
Former User's Avatar
^This
Old 01-24-2011, 12:20 PM
Woody.'s Avatar
Not a rodent, it doesnt smell like something died. It just has an awful smell.
Is there any other way without removing dash, its cold and rainy all week...
Old 01-24-2011, 12:26 PM
Death stinks.
Old 01-24-2011, 12:41 PM
itsnotfast's Avatar
Originally Posted by RonJ@HT
Death stinks.
Lol, this is true.
Old 01-24-2011, 01:16 PM
Woody.'s Avatar
I know but it doesn't smell like that.
Old 01-24-2011, 01:39 PM
You may need to remove the dash to inspect the air ducts and heater core (and the evaporator if you have A/C). In the meantime, removal of three screws under the dash will drop the blower motor down. Check whether this exposes anything resembling a corpse or feces.
Old 01-25-2011, 07:11 AM
Woody.'s Avatar
Nope no corpses or feces.
Old 01-25-2011, 08:28 AM
That's unfortunate as now there's much more work for you to do. With the blower removed, do you smell the bad odor inside the air duct? Did you use a mirror and light to look inside the duct for foreign objects?
Old 01-25-2011, 08:46 AM
Dontoh's Avatar
is it possible it smells like burning coolant or something?
Old 01-25-2011, 12:38 PM
Woody.'s Avatar
Thanks for the diagram.
Took my car out today...
Heater took 45 minutes to start blowing hot.
Car was at normal temp within 2 minutes.
Could these be related?
Old 01-25-2011, 12:44 PM
Is the coolant level low in the radiator or reservoir?
Old 01-25-2011, 12:49 PM
Woody.'s Avatar
Dont have a reservoir - but coolant/water and waterwetter is still in there.
Would low coolant smell like poo ****?
Old 01-25-2011, 12:54 PM
You MUST have a coolant reservoir. Don't run the engine without one. When the engine is hot, coolant spills out of the radiator, and when it cools, air is getting sucked into the cooling system. After you install a reservoir, then top off with coolant and then bleed the cooling system.
Do you see any moisture dripping from under the dash? Are your carpets wet?
Do you have A/C?
Old 01-25-2011, 01:18 PM
Woody.'s Avatar
I have to get my radiator set back up for one then. Got it like that with the car.
No moisture, carpets aren't wet. I do have A/C tho.
Old 01-25-2011, 01:21 PM
You may be able to get a cheap reservoir at a junk yard. Keep the radiator topped off with coolant (not water), and get a reservoir ASAP before you destroy the engine.
If the A/C drain hose from the evaporator is clogged, water can get trapped in there and fester.
Old 01-25-2011, 01:28 PM
Woody.'s Avatar
Ac hoses, compressor and evaporator can are brand new and were installed this summer.
I have to get something welded to my radiator to run a resorvoir.
Old 01-25-2011, 01:35 PM
Woody.'s Avatar
Do you know what size outlet the reservoirs use?
Old 01-25-2011, 01:38 PM
Not sure. The reservoir just slides into a bracket on the frame.
Old 01-25-2011, 01:41 PM
Woody.'s Avatar
I meant the piece that the hose connects to. Its at a 90 Degree angle above the reservoir.
Old 01-25-2011, 01:44 PM
Sorry, not sure.
Quick Reply: 00 civic ex heater smells terrible.
