00 Civic Ex Code 65 secondary o2 heater circuit
Old 03-03-2016, 10:58 PM
Loyalhondahaver's Avatar
Default 00 Civic Ex Code 65 secondary o2 heater circuit
Hello all. Just swapped a y7 from a 99 Civic LX into a 00 Civic EX.
I used the y7 harness and computer.
5-10 seconds after start up, I get code 65. I swapped computers with another and also get code 65.
Ron J posted this info on another "code 65" thread years ago:
The O2 sensor wires (ignore these wires for code 65):
1. Wht to Wht/Red wire pins to ECU D14.
2. LtGrn to Red/Yel wire pins to ECU D13.
The heater element wires:
3. Blk to Blk/Yel wire that gets power through dash fuse 15 should have battery voltage with the key in ON(II).
4. Blk to Blk/Wht wire pins to ECU A5.
The following three tests are done with all ECU connectors plugged in and the secondary O2 sensor unplugged:
a) Is fuse 15 blown?
b) With key in ON(II), do you measure battery voltage between terminal 3 (+) and terminal 4 (-) in the O2 sensor wire harness connector?
c) With key in ON(II), do you measure battery voltage between terminal 3 (+) and engine ground (thermostat housing) in the O2 sensor wire harness connector?
I did these tests, (kind of).
I didn't use a multimeter but a test light.
My test light lit up for both test B and C.
Fuse 15 is not blown.
Should I use a multimeter now (must get one and learn to use it) or will my test light test suffice?
I have swapped the secondary o2 for two other known good ones and the code reappears in the same amount of time. (ECU reset every time before testing)
Help!
Old 03-04-2016, 05:43 AM
Former User's Avatar
Default Re: 00 Civic Ex Code 65 secondary o2 heater circuit
There could be a short in one of the heater element wires or the Y7 ECU is bad.
Start by buying or borrowing a multimeter.
Also post a picture showing the wire harness connector for the secondary O2 sensor and the 4 wire colors.
Old 03-04-2016, 12:27 PM
Step one- complete. Headed home for testing. Have to figure out where to set the dial.
Old 03-04-2016, 12:36 PM
Multimeter Tutorial - Voltage
You will use the Ohms (resistance) and DC voltage settings. I didn't see a continuity setting on your multimeter, but that's not required.
Old 03-04-2016, 12:50 PM
Thank you. I'll probably have to return this one later and get one that can test for continuity for when I master the thing. Studying now!
Old 03-04-2016, 12:56 PM
The Ohm setting is sufficient to test for continuity.
The only difference is that the continuity setting makes a beep sound when continuity is detected. It's really just a convenience feature rather than a required feature.
Old 03-04-2016, 01:14 PM
My secondary o2 plug and it's wire colors.
Old 03-04-2016, 01:19 PM
Good. That's the correct plug.
Start by measuring voltage across your two battery posts. Install meter probes. Dial the meter to the 20V DC range. Touch red meter probe to (+) post and black meter probe to (-) post. The reading is referred to as battery voltage for your car.
Old 03-04-2016, 01:58 PM
Test c:
on the harness side connector for the secondary o2, (the one pictures) the black/yellow wire to body ground give me 11.92 v. With my multimeter set at DCV 20.
Test B:
On the harness side connector for the secondary o2, (the one pictured) the black/yellow wire to the black/white wire i get no readings.
Bad black/white wire?
Old 03-04-2016, 02:04 PM
Originally Posted by Loyalhondahaver
Test c:
Test B:
These^ two tests are the same as B and C using a test light in your first post. Why are you now getting different results using the multimeter?
Old 03-04-2016, 02:07 PM
I guess I messed up some how. Possible I did the test with other other ECU. Although I got the same code with both ECUs, I'll switch them again and see if I get the same results.
Old 03-04-2016, 02:09 PM
Turn key to ON(II) and then repeat test B.
Old 03-04-2016, 02:13 PM
Key turned to ON(II), repeated test B with both ECUs, same results- no reading.
Old 03-04-2016, 02:21 PM
I did that. No readings. Also just threw in a y8 ecu and tested, no reading.
Old 03-04-2016, 02:26 PM
Can you locate this connector?
Old 03-04-2016, 02:30 PM
Yes, I have located it.
Old 03-04-2016, 02:52 PM
On the male-pin and female-pin sides of C131, are there Blk/Wht wires at pin 1?
After you have the answer, look at these two diagrams:
D16Y7
D16Y8
Old 03-04-2016, 03:12 PM
There is a black/white on the male side and nothing on the other side.
Studying now.
Old 03-04-2016, 03:18 PM
The missing Blk/Wht wire is the problem. The 99 Civic LX D16Y7 harness had a Blk/Wht wire on both sides of C131 (pin 1), but the 00 Civic EX did not because the Blk/Wht wire bypassed C131 and went directly from C432 to ECU connector A.
Old 03-04-2016, 03:31 PM
Awesome! So I believe I have two options:
1. Install 99 LX cabin harness
2. Depinned the black/white wire we are speaking of and pin in into the correct spot on connector A.
Does that sound right? Option 2 sounds like the best idea.
Old 03-04-2016, 03:36 PM
The missing wire is on the engine harness side of C131.
Old 03-04-2016, 03:48 PM
Thanks so much Ron.
Working on depinning now.
I have the existing black/white white from the y8 cabin harness depinned. (Commector A slot 8)
Now I'm working on depinning the black/white wire from the male side of connector 131 from the y7 harness. This connector pins differently it seems. Not as easy to depin.
Then I will pin black/white wire from c131 into slot 8 or connector A, leave old black/white hanging and she should work!
What website do your factory diagrams and what not come from?
Old 03-04-2016, 03:55 PM
Are you using the Y8 secondary O2 sensor that plugs into the cat under the console or the Y7 secondary O2 sensor that plugs into the header/cat combo at the front of the engine?
Locate the 96-00 Civic service manual in a Google search and download it.
Old 03-04-2016, 04:01 PM
I am using the y7 sensor that plugs into the bottom on the cat on the bottom of the exhaust manifold.
Old 03-04-2016, 04:07 PM
1) Test the Blk/Wht wire on the male-pin side of C131 for continuity with pin A8 in ECU connector A. If you find continuity, proceed to step 2.
2) Run a new Blk/Wht wire from the secondary O2 sensor connector to the female-pin side of C131.
There should be no code 65 after this is done.
Quick Reply: 00 Civic Ex Code 65 secondary o2 heater circuit
