00 civic dx throwin' codes like dollaz - p0300 p0301 p0302 p0303 p0304 p1399
Old 10-04-2010, 05:14 PM
sanchg3's Avatar
Default 00 civic dx throwin' codes like dollaz - p0300 p0301 p0302 p0303 p0304 p1399
I am new at this so i hope i say this right i have a 2000 honda civic dx i just got the check ingine light on and it gave me the codes p0300 p0301 p0302
p0303 p0304 and p1399 and dont know what to do anymore help plz
Old 10-05-2010, 08:54 AM
sanchg3's Avatar
Default Re: Honda problem
Yes it is man 2000 Honda civic hatch back dc
Old 10-05-2010, 09:06 AM
kaiba's Avatar
All your answers are here. https://honda-tech.com/forums/tech-misc-15/heres-list-obd2-codes-if-anyone-cares-466877/
Old 10-05-2010, 09:47 AM
sanchg3's Avatar
sorry 2000 honda civic dx do anybody know how to fix the problem
Old 10-05-2010, 09:50 AM
kaiba's Avatar
Did it just happen all of the sudden? We need more info/background story about the car. Stock, engine code, swap, wiring?
Someone move this to the correct forum.
Old 10-05-2010, 10:08 AM
sanchg3's Avatar
This happen about 2 months ago i have had the car for about a year with no problems but know this came up p0300 p0301 p0302 p0304 p1399 it says that the cylinders are misfiring and have change the spark plugs the bothe cap and router and also the fuel injector madulator and the o2 sensor and nothing the car would not even stared i have to idel it
Old 10-05-2010, 12:56 PM
kaiba's Avatar
Check your timing.
Old 10-05-2010, 04:04 PM
sanchg3's Avatar
Ok I will check that out I just tried to stared the car and nothing it just sounds like it wants to but nothing it only sputtering
Old 10-06-2010, 05:40 AM
sanchg3's Avatar
Ok check the timing and that was not it any other suggestions
Old 10-06-2010, 05:53 AM
Cool Cool Island Breezes. BOY-EE
B serious's Avatar
You've all been had.
Original poster: check the 92-00 civic section. In the top area they have a thread on check engine lights (CELs). Check what your codes mean. Then fix.
Old 10-06-2010, 07:41 AM
sanchg3's Avatar
Sorry what section do I go to and how I am new at this
Old 10-06-2010, 08:34 AM
MiG-21 superfan
builthatch's Avatar
OP i moved this to the appropriate section, 92-00 honda civic. you were in the section for the honda s2000.
Old 10-06-2010, 09:02 AM
Former User's Avatar
Default Re: 00 civic dx throwin' codes like dollaz - p0300 p0301 p0302 p0303 p0304 p1399
You have a bad case of random misfires on all four cylinders. Start by checking/replacing the spark plugs, wires, cap, and rotor. And if the fuel filter is old, also replace it.
Old 10-06-2010, 10:10 AM
sanchg3's Avatar
Icon4 Re: 00 civic dx throwin' codes like dollaz - p0300 p0301 p0302 p0303 p0304 p1399
I just replace the cap and router fuel filter is new all so replace the fuel injecter modulater I tried staring the yestreday and know it won't even stared up help
Old 10-06-2010, 10:11 AM
MiG-21 superfan
builthatch's Avatar
OP where are you located.
Old 10-06-2010, 10:16 AM
What about the spark plugs and plug wires?
If those are fine, then test the coil and have an auto parts store test the ICM for you.
Old 10-06-2010, 10:36 AM
sanchg3's Avatar
My wires r new and I will test the icm I willing to try anything about know I am located in California
Old 10-06-2010, 10:40 AM
My wires r new
What about the spark plugs? Have you inspected them? Are they properly gapped? What brand are you using?
Old 10-06-2010, 10:55 AM
I...replace the fuel injecter modulater
What is this? Is the engine modified or stock?
Old 10-06-2010, 12:03 PM
sanchg3's Avatar
The engine is stock and I am using Bosch plugs
Old 10-06-2010, 12:08 PM
devney's Avatar
Switch to NGK's.
Old 10-06-2010, 12:38 PM
Jimster480's Avatar
Originally Posted by devney
Switch to NGK's.
while he should probably switch to NGK's. I doubt this is his problem.
Old 10-06-2010, 12:41 PM
Switch to NGK's.
I would do this^, and then go from there.
Old 10-06-2010, 01:28 PM
sanchg3's Avatar
ok i will check my coil and my icm and change my plugs to ngk,s i will get back to u
Old 10-06-2010, 05:23 PM
sanchg3's Avatar
Ok just the icm and the coil and they both pass but still won't start
Quick Reply: 00 civic dx throwin' codes like dollaz - p0300 p0301 p0302 p0303 p0304 p1399
