[FAQ] Ultimate Swap Quick Ref. for EG/EK
Old 10-16-2010, 12:55 PM
TwoFacedCustoms's Avatar
Default [FAQ] Ultimate Swap Quick Ref. for EG/EK
There seems to be a constant flow of "What parts do I need to swap XX engine into XX vehicle" threads.
This thread is an attempt to collect...and organize all of those threads and ideas using everyone's knowledge put together to make a quick reference, and a good starting point so people know the bare essentials to swap alot of the popular motors into a 92-00 civic, and know different options for ways to keep PS/AC and other components when performing swaps.
The original post will be constantly updated as everybody supplies the thread with new information. I'm not claiming to have a vast knowledge of swaps...I'm bored at work and figured this would save alot of people alot of time and help avoid conflicting information...that's why I'm relying on you guys to help with this.
If you have any info on parts list/what needs to be modded/can be retained from original setups for swaps please post on here or PM me...all swap details will be welcome. If it's a unique swap, and you know all the parts necessary feel free to post. Even if it's just additional ideas to current lists, the more knowledge the better!
IF YOU THINK THIS IS A BAD IDEA DON'T POST! No need to harass for something you think is a bad idea. No hating for an attempt to help the masses. If something is wrong on the write-up...politely let me know and it will be changed/modified.
If you read this post please bump so we can keep it on top and people will hopefully keep supplying new info.
Thanks in advance.
B18B (OBD2 LS) into 96-00 Civic
-Complete Long Block
-B-Series: Driver// Passenger Side Axles
-Axle Half shaft
-Clutch Kit (( Flywheel, Pressure Plate, Clutch Disc ))
-Transmission
-Shift Linkage
-P75 ECU
-OBD2 Integra Engine Harness (Source for necessary plugs)
-99-00 Si T-Bracket + Timing Belt Bracket
-B-Series Mounts (( I.E. Innovative B-D series mounts ))
-Integra shift linkage
-P54 AC Bracket from CRV if you want to retain AC *I believe there's also a del-sol bracket that's usable if anybody can verify*
Keep the stock harness.
'96 - '98 civic you'll simply have to extend the wiring for the O2 sensor and convert from a 3 wire to 2 wire IACV, and IIRC swap plugs for the CKF sensor.
'99 - '00 you'll also have to deal with the distributor plug.
If you're running an OBD2 USDM ECU perform the CKF trick shown here ---> http://technet.ff-squad.com/ckftrick.htm
Using a D16y7 (( obd2a )) engine harness to plug up to a JDM obd2 LS:
The factory's plastic covers and tape prevent some of the connections from reaching their designated location i.e. fuel injector connectors and a couple other unknown plugs...
Take the plastic piece that goes around the injector wires and bolts to the fuel rail off the JDM engine and put it on your Y7, extend wires where needed (Cut JDM harnesses are a great source for correct colored wire of the right gauge) Any time you have to splice anything use solder and shrink tubing, try to make splices away from plugs.
K-Series into 92-00 Civic
-K series motor
-K series tranny
-k series ecu
-K series engine harness
-K series charging harness
-K series intake and throttle body
-Motor mounts
-Conversion harness
-Axles (Don't have to use after market axles, you can make your own from B-Series outers and K inners)
-Clutch line
-Radiator package
-B/D series coolant temp sensor and fan switch
-Fuel rail
-Fuel Pressure regulator
-Custom Fitted Fuel lines
-OEM RSX shifter Box or Modified Accord shifter box
-RSX shifter cables
-Shifter linkage clips
-Aftermarket or DIY Intake
-Aftermarket header
-Custom Mid Pipe
-Throttle cable for your application
Old 10-16-2010, 07:40 PM
SHG_Claudio's Avatar
Default Re: [FAQ] Ultimate Swap Quick Ref. for EG/EK
Good idea. About time we have this.
Old 10-16-2010, 07:58 PM
Thank you...it'll take some time because the info is so contradicting from post to post but with time I think it will save alot of people alot of research and time.
Have any input by chance?
Old 10-16-2010, 08:08 PM
Yeah. Main thing here is keeping it neat. Such as chassis codes and engine codes listed. I do know that 92 Civics are prewired for VTEC regardless of trim even if they didn't come with VTEC.
Old 10-16-2010, 08:17 PM
Zombie Nachos's Avatar
Bump for looking at this post. Awesome idea for a possible sticky!
Old 10-17-2010, 09:28 AM
I have links for more specific write-ups with almost complete details and pictures on these and other swaps I'm just waiting to get permission from the users to post.
Threw down some K-swap basics today...feel free to provide input if something is missing or you know more specifics.
BUMP IF VIEWED PLEASE!
Old 10-17-2010, 06:57 PM
I like it, very good base list to get started on.
Old 10-17-2010, 08:37 PM
mortificationrock's Avatar
Good ****...hopefully it will stop all the same threads regarding swaps.
Old 10-17-2010, 09:44 PM
King of Lions
Mufasa's Avatar
why don't you also add the H series in addition? Very good start so far
Old 10-17-2010, 10:07 PM
98corbeau coupe's Avatar
nice write up how ab the b18c1 into a ek coupe ?
Old 10-18-2010, 07:19 AM
H Series is pretty much done...I can look into the c1 tonight. I have to work and I'll have nothing to do so hopefully I get a bit more accomplished on all this...thanks for the support guys.
RedSix
04-30-2010 12:07 PM
bum916
04-13-2009 08:04 PM
BOMBAY
04-22-2008 06:04 PM
99JDMEK
04-20-2006 09:10 AM
Quick Reply: [FAQ] Ultimate Swap Quick Ref. for EG/EK
