[FAQ] Detailed How To: Remove Rear / Back Seat From An EH Hatch! - Honda-Tech
Old 05-21-2003, 11:39 PM   #1
VX
VX's Avatar
Default Detailed How To: Remove Rear / Back Seat From An EH Hatch!
Tools Required: 10mm, 17mm Sockets.
Total Time: 10 Min.
BEFORE:
STEP 1: Pull up on release ***** on both folding seats.
STEP 2: Fold both seats down.
STEP 3: Pull out the clip pin on both sides of the rear seats, where the seats pivot.
STEP 4: Slide both seats outwards towards the side panels, so the seats are released away from the center metal brace thing.
Here's pics of what the hole looks like on the sides of the seats, and the center metal brace that goes in the holes.
STEP 5: After releasing the seats from the center metal brace thing, lift them up at an angle and slide the rest of the seats out by moving it towards the center, so the pin on the sides of the seats are released from the holes in the side panels.
STEP 6: Remove both back rests from the car.
Here is a picture of the hole in the side panels where the pins from the seats went into.
STEP 7: Locate and unscrew the 10mm bolt holding in the seat cushion.
STEP 8: Pivot the seat cushion up gently, as you push the seat belts through the holes in the cushion.
STEP 9: Locate the 2 metal "hooks" on the bottom of the seat cushion, they are on opposite sides of each other. Then pivot the seat cushion up and out so the hooks come out from their holes.
STEP 10: Unscrew the 4 bolts holding in the seat belt buckles using a 17mm socket.
AFTER:
WEIGHT SAVINGS:
Rear back rests:
Weight: ~ 20 lbs.
Rear seat cushion:
Weight: ~ 7 lbs.
TOTAL WEIGHT SAVINGS: ~27 lbs.
Detailed carpet removal coming soon!!!
Modified by VX at 12:01 AM 5/22/2003
VX is offline   Reply With Quote
Old 05-21-2003, 11:45 PM   #2
Solbros Owns Me
Evs-One's Avatar
Default Re: Detailed How To: Remove Rear / Back Seat From An EH Hatch! (VX)
jk
Evs-One is offline   Reply With Quote
Old 05-21-2003, 11:45 PM   #3
sweet writeup.....this will come in handy for me manana
SpoonFedHatch is offline   Reply With Quote
Old 05-21-2003, 11:46 PM   #4
vivid02's Avatar
I wonder if there are actual people who don't know how to remove there seats.
vivid02 is offline   Reply With Quote
Old 05-21-2003, 11:47 PM   #5
VX
VX's Avatar
Default Re: (SpoonFedHatch)
Thanks, i have all the pics for the carpet removal, i just need to do a write up on that too!
Old 05-21-2003, 11:47 PM   #6
Solbros Owns Me
Evs-One's Avatar
Default Re: Detailed How To: Remove Rear / Back Seat From An EH Hatch! (vivid02)
Old 05-21-2003, 11:48 PM   #7
careawholelot's Avatar
nice detail on how to remove rear seats, but if somebody didn't know how to remove the back seats before they should have never gotten there license.
careawholelot is offline   Reply With Quote
Old 05-21-2003, 11:48 PM   #8
i dont....i've never done it, not that it seems hard, but this how-to is Dr. Suess friendly
Old 05-21-2003, 11:49 PM   #9
B2FiNiTY's Avatar
Very nice writeup!
B2FiNiTY is offline   Reply With Quote
Old 05-21-2003, 11:49 PM   #10
esoterEK..'s Avatar
Default Re: Detailed How To: Remove Rear / Back Seat From An EH Hatch! (Emerika)
esoterEK.. is offline   Reply With Quote
Old 05-21-2003, 11:51 PM   #11
kefka's Avatar
Default Re: Detailed How To: Remove Rear / Back Seat From An EH Hatch! (B2FiNiTY)
lol nice...
kefka is offline   Reply With Quote
Old 05-22-2003, 12:11 AM   #12
acuracing's Avatar
I'm assuming you calibrated the scale with the plywood and cans on it, right?
acuracing is offline   Reply With Quote
Old 05-22-2003, 12:20 AM   #13
EddieHatchBlack's Avatar
Default Re: Detailed How To: Remove Rear / Back Seat From An EH Hatch! (acuracing)
now do an EK one! (j/k)
EddieHatchBlack is offline   Reply With Quote
Old 05-22-2003, 01:44 AM   #14
I Kick Squirrels's Avatar
Default Re: Detailed How To: Remove Rear / Back Seat From An EH Hatch! (Eddie HatchBlack)
i have never taken my seats out but i am pretty sure that i could figure it ouy
haha nice write up anyway
I Kick Squirrels is offline   Reply With Quote
Old 05-22-2003, 01:48 AM   #15
VX
VX's Avatar
Quote:
Yes i tested it several times with weights and what not to get an accurate reading.
BTW: Carpet Removal How To is now up: http://honda-tech.com/zerothread?id=512955
Old 05-22-2003, 04:30 AM   #16
Nice write up, sure to help many others in the future.
Maximus is offline   Reply With Quote
Old 05-22-2003, 06:17 AM   #17
Bumnah's Avatar
Default Re: Detailed How To: Remove Rear / Back Seat From An EH Hatch! (Maximus)
remove the side panels and weigh those so i know how much i saved by removing those too
Bumnah is offline   Reply With Quote
Old 05-22-2003, 07:16 AM   #18
EH339's Avatar
Good post. Nice red hatch there. I've had my back seats out for years. And my front passenger seat is usually pulled out too.
EH339 is offline   Reply With Quote
Old 05-22-2003, 09:07 AM   #19
AThiker's Avatar
Default Re: Detailed How To: Remove Rear / Back Seat From An EH Hatch! (94RedSiGal)
Good write-up. 27 lbs - good to know
AThiker is offline   Reply With Quote
Old 05-22-2003, 09:29 AM   #20
New User
ELUD THS's Avatar
Default Re: Detailed How To: Remove Rear / Back Seat From An EH Hatch! (jgop_151)
ELUD THS is offline   Reply With Quote
Old 05-22-2003, 05:12 PM   #21
VX
VX's Avatar
Default Re: Detailed How To: Remove Rear / Back Seat From An EH Hatch! (ELUD THS)
Thanks for the comments
Old 05-22-2003, 05:19 PM   #22
Unceasing Measure
Archidictus's Avatar
So...now nobody can sit in the rear of your hatch and you saved 27 pounds: not enough weight to drop your ET any significant amount (.027 seconds if you're a driver who can replicate his best passes with 100% precision).
What's the point?
Excellent writeup and brilliant pictures though .
Archidictus is offline   Reply With Quote
Old 05-22-2003, 05:40 PM   #23
rodrez.'s Avatar
Default Re: Detailed How To: Remove Rear / Back Seat From An EH Hatch! (Archidictus)
Quote:
Originally Posted by Archidictus
So... now nobody can sit in the rear of your hatch and you saved 27 pounds: not enough weight to drop your ET any significant amount (.027 seconds if you're a driver who can replicate his best passes with 100% precision).
What's the point?
rodrez. is offline   Reply With Quote
Old 05-22-2003, 06:41 PM   #24
VX
VX's Avatar
What's the point?
I see what you're saying, and it makes sense, I didn't remove my seats to shave off ".027 seconds" I did it because i really have no use for it. My friends don't like sitting back there, and removing it didn't cost me any money. This is purely opinion based... but, i kind of like the striped hatch look, so i didn't hesitate to remove it.
And thanks for the comments!
Old 06-04-2003, 11:16 PM   #25
VX
VX's Avatar
Tar removal is now up: Click Here
How I Lost 114 Pounds In 26 Hours! And You Can Too! VX Honda Civic / Del Sol (1992 - 2000) 118 12-14-2005 11:51 PM
Enkei RS-Evolution 3 Piece vuthe32 For Sale 26 10-12-2003 04:15 PM
the new look 95integrags-r Honda / Acura 38 06-27-2003 05:01 AM
92-95 Civic COUPE Wings West Side Skirts and bumper skirt and 96-00 Civic power mirrors. IdotheSHOCKER For Sale 6 06-16-2003 07:31 PM
Pics of Vtecvoodoo's SO CAL meet (Post your pics in here..and come find your car=) 56k..come on in ( ScaleExtric Honda / Acura 106 06-12-2003 10:15 PM
Tags
97, accord, back, backseat, bolt, civic, hatch, honda, lexus, rear, remove, removing, sc300, seat, seats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
