**Timing a b18c1 with no timing cover**
Old 01-12-2011, 07:39 AM
ToTriggerHappy's Avatar
Default **Timing a b18c1 with no timing cover**
How would i go about timing my b18c1 with no upper or lower timing cover?
Old 01-12-2011, 08:56 AM
JDM-sol 89's Avatar
Default Re: **Timing a b18c1 with no timing cover**
Turn your crank, by hand or socket while your plugs out, until the outside two pistons are all the way up (cylinder 1 and 4). Then on your cams, line the two little marks so they're facing each other and the arrows are pointing up.
Old 01-12-2011, 09:01 AM
apexi_rsx's Avatar
usally on the oilpump there is a mark to line the crank key up to then time the top. the cams have a fish eye above the cams ( by the cam gears) u can lock the cams with a drill bit or a 10mm bolt.
Old 01-12-2011, 11:52 AM
i mean using a timing light and turning the distributor. I know on my D series they have a mark on the bottom timing cover and three marks on the harmonic balancer.
Old 01-12-2011, 04:27 PM
bump
Old 01-12-2011, 05:38 PM
bump
Old 01-12-2011, 06:26 PM
92civlude's Avatar
Does your pulley have timing marks? Remove the crank pulley and set to TDC on the timing belt pulley and the arrow cast into the oil pump. Put the crank pulley back on, But dont tighten it. Try to make a reference mark on the block and line it up with the white "T" on the crank pulley. Tighten the crank pulley. Now at least youll have a 0 degree reference. You should be able to get it close with an adjustable timing light. Set the timing light to the timing spec. and check timing by lining up the marks on the pulley and the mark you made. Good luck.
Old 01-12-2011, 08:21 PM
sounds like alot of **** to time my engine. lol
Old 01-13-2011, 06:31 AM
92civlude's Avatar
HA! Its either that or get some covers!
DavidCRV
08-26-2013 03:12 PM
94dxt
10-27-2004 12:36 PM
WannaHonda
05-06-2004 10:12 AM
boostedcvc
12-22-2003 10:24 AM
Quick Reply: **Timing a b18c1 with no timing cover**
