Old 04-01-2015, 02:01 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension Guides
Print Wikipost
**Need help! loud squeak sound when turning the wheel**!!!
Old 01-24-2010, 07:00 PM
xkrazyxjbrkerx75's Avatar
Default **Need help! loud squeak sound when turning the wheel**!!!
Everytime i turn the wheel to the left or right, it something squeaks really loud, but idk what it is, maybe steering rack? tie rod? ball joints? help!
xkrazyxjbrkerx75 is offline
Old 01-24-2010, 07:38 PM
z6htch's Avatar
Default Re: **Need help! loud squeak sound when turning the wheel**!!!
Do you have power steering?
It could be the belt, not sure of your situation. Just trying to help.
z6htch is offline
Old 01-24-2010, 07:42 PM
yes i do have power steering, a belt? idk if it is the power steering though, theirs plenty of fluid in it.
Old 01-24-2010, 07:45 PM
z6htch's Avatar
The belt that runs from the power steering pump to the crank pulley. If it gets wet or loose, it may squeak or more of a squeal.
You may want to replace it, shouldn't cost that much at parts store.
z6htch is offline
Old 01-24-2010, 07:48 PM
does it matter if the car is on or not? when the car is off, it squeaks loud as hell!
Old 01-24-2010, 07:50 PM
z6htch's Avatar
Yeah it would NOT squeak when the car is off, may be bushings.
Somebody help this guy out.
z6htch is offline
Old 01-24-2010, 08:16 PM
yes help please! maybe could be steering rack? tie rod ends? as im guessing
Old 01-24-2010, 08:34 PM
EgonzEk's Avatar
I believe your problem is going to be either your ball joints or tie rods. once this parts get dry they start squeaking. go to each side of the car and jounce it, this way you will be able to isolate the problem to the side where its coming from. check the boots that cover the ball joints or tie rods, if they are ripped most likely thats the problem.
EgonzEk is offline
Old 01-25-2010, 10:51 AM
im guessing its the whole tie rod end with the ball joints
Old 01-25-2010, 10:55 AM
eatsleephonda90's Avatar
its your power steering pump giving out trust me it happened to me with my 92 accord it would make loud squeaking noise everytime i turned, you can get one at a junk yard for like 50 bucks it comes with the pully also.
eatsleephonda90 is offline
Old 01-25-2010, 12:08 PM
JonBob's Avatar
Well if your car squeaks when its not running it can't have anything to do with the power steering.
I'd say go to any tool store and get a stethoscope, put it on the ball joints and outter tie rods one at a time. You'll know right off which one it is when you find it. This is also a good tool to have for diagnosising other noise issues too.
JonBob is offline
well also when i hit bumps, it also squeaks without turning the wheel
Old 01-25-2010, 12:10 PM
JonBob's Avatar
Forgot to mention the obvious, have a buddy turn the wheel for you.
JonBob is offline
Old 01-25-2010, 04:52 PM
well it can be anything to be honest
Old 01-27-2010, 07:53 PM
f22a's Avatar
I had the same problem on my '04 F-150, and it was the lower ball joints. It's a different vehicle, but conceptually the suspension is the same. Go out and check the boots on the ball joints to see if they are torn.
f22a is offline
Old 01-27-2010, 07:55 PM
i replaced the lower ball joints, was thinking it could be the upper or the tie rod end ball joint
Old 01-27-2010, 10:22 PM
redeg666's Avatar
push the brake dust sheild away from the brake rotor
redeg666 is offline
Old 01-28-2010, 11:23 AM
already did that
Old 01-28-2010, 11:56 AM
D Griff's Avatar
This is sort of a dumb solution, but when i used to live in NC where it was cold in the winter my steering wheel would squeak, I think just because some parts contracted and thus rubbed. When it warmed up it stopped. I just dealt with it until my car warmed up though and it never caused a problem.
D Griff is offline
Old 01-28-2010, 06:21 PM
hmmm, not sure if thats the problem.. but thanks!
Old 01-28-2010, 06:45 PM
Red_Army's Avatar
its probably one of the weight bearing ball joints in your car.
could be a spring thats sqeaky but i doubt it.
Red_Army is offline
Old 01-28-2010, 07:09 PM
94BlkCivicEx's Avatar
This recently just happened to me as well. It ended up being my ball joint. Might wanna get it checked out fast cause i kinda blew mine off for a couple weeks than one day doing about 5 mph the ball joint popped out of place and snapped my axle.
94BlkCivicEx is offline
Old 01-28-2010, 08:16 PM
which ball joint are u talking about, tie rod end? or the upper one? i just replaced my lower one.
Old 01-28-2010, 08:53 PM
Upper ball joint, than about a month later my left side went out to haha
Old 01-29-2010, 04:48 PM
so its the upper ball joint?
Quick Reply: **Need help! loud squeak sound when turning the wheel**!!!
