**HELP** F20b into Ek Motor Mount Problem
Heres the deal, putting a f20b in to my ek but having trouble with the driver side mount. bought an Avid kit for H22 into civic96-00, the driver side mount wont fit the block studs. the studs arent parallel on the block bracket and the mount one are. Someone Please fill my bucket with water!!!
you will need to use the block bracket that matches the mount, or make a custom mount. the f20b came out of an accord so its not surprising that it uses a diff mount on the timing belt end.
Re: **HELP** F20b into Ek Motor Mount Problem (omar6686)
look around here on honda tech, ebay, or the dealer cause you need to get the motor mount bracket from the h22s. I did that with my brothers f20b same issue but at least he already had the h22 mtr so i and since i was doing the timing service to the motor before installing it, it was gravy
