** Passenger side Floor is ALWAYS WET after rain ** - Honda-Tech
Old 04-22-2003, 04:31 PM   #1
mz3bo's Avatar
Default ** Passenger side Floor is ALWAYS WET after rain **
I have this major problem, there is not rust no where on the car and the car had never been into an accident or somewhat... But, after it rained a lot, the passenger side floor is always soaked with water... I can't see from where it is coming from, anyone here ever experimented such situation ?
Thanks
mz3bo is offline   Reply With Quote
Old 04-22-2003, 04:33 PM   #2
Default Re: ** Passenger side Floor is ALWAYS WET after rain ** (mz3bo)
leaky door seal...
IS3Fifty is offline   Reply With Quote
Old 04-22-2003, 04:38 PM   #3
tonyxcom's Avatar
have you recently had your windshield replaced? Or do you know if it has ever been replaced?
tonyxcom is offline   Reply With Quote
Old 04-22-2003, 05:43 PM   #4
mz3bo's Avatar
Nah... none of those situations happened recently
Old 04-22-2003, 05:46 PM   #5
Del
What car are we talking about here???
If it's a Sol it's definitely your front seals
Del   Reply With Quote
Old 04-22-2003, 05:47 PM   #6
mz3bo's Avatar
It's a 92 Civic HB DX
Old 04-22-2003, 05:47 PM   #7
Sijray21's Avatar
does it only happen when you drive in the rain, i used to have that problem, ended up being a leak from the wheel well.
Sijray21 is offline   Reply With Quote
Old 04-22-2003, 05:48 PM   #8
Risky Business
BauleyCivic's Avatar
Default Re: ** Passenger side Floor is ALWAYS WET after rain ** (Sijray21)
yaeh...have all ur seals checked...window seals, door seals, hood seals, and trunk seals...my friends coupe is leaking...we believe its a leaky trunk seal
BauleyCivic is offline   Reply With Quote
Old 04-22-2003, 05:49 PM   #9
Risky Business
Quote:
yeah and check that seal too
Old 04-22-2003, 05:49 PM   #10
mz3bo's Avatar
Default Re: ** Passenger side Floor is ALWAYS WET after rain ** (BauleyCivic)
It only happens when the car is parked... especially if the right side of the car (passenger) is tilting lower than the driver side...
Old 04-22-2003, 06:29 PM   #11
Zanpakuro's Avatar
Do you have a amp? Cause my car leaks also.
I had to cut the rubber grommet to run the wire to the battery
Zanpakuro is offline   Reply With Quote
Old 04-22-2003, 07:51 PM   #12
Slow CX's Avatar
Default Re: ** Passenger side Floor is ALWAYS WET after rain ** (TODAeg6)
Quote:
Originally Posted by TODAeg6
leaky door seal...
I will go with that to. Mine does the same thing. It leaks like above the handle for the window where the door closes.
Slow CX is offline   Reply With Quote
Persistent water leak in 2005 Hybrid Honda Accord even after taking it to mechanic 2X enzqt Honda Accord & Crosstour (2003 - Current) 7 04-23-2015 01:06 PM
Passenger side water leak ricerEJ8 Acura Integra 4 01-10-2008 04:15 AM
Water on floor of passenger side of car after rain Mayorseed Honda Accord (1990 - 2002) 4 11-01-2007 05:51 AM
Leak on passenger side. galla013 Honda Civic / Del Sol (1992 - 2000) 3 08-25-2007 02:38 PM
'91 Lx taking in water eWock Honda Accord (1990 - 2002) 4 02-04-2006 12:10 AM
Tags
2002, car, civic, corolla, drivers, floor, g20, honda, hondacivicegpassengerwet, leak, passenger, rain, side, water, wet
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
