*** The BASICS: No Start Diagnosis 101 ***
Old 07-08-2016, 11:04 AM
  #51
Hysterically Calm
TomCat39's Avatar
Default Re: *** The BASICS: No Start Diagnosis 101 ***
Originally Posted by brians356
Just curious, why counter-clockwise, and how critical is the direction here?
These older motors spin counter clockwise and is an interference motor with sometimes only .001" space between an open valve and the piston. The tension on the timing belt is designed for that direction. Going clockwise can cause the belt to be at less tension which in turn could cause the mechanical timing to shift enough that you don't have the .001" clearance and end up kissing a valve against the piston.
Granted you are only hand turning the motor but it's best to not even allow that as a possibility.
In later motors (K24 I think) Honda reverted to a clockwise turning motor.
TomCat39 is offline
Old 07-08-2016, 11:09 AM
  #52
brians356's Avatar
Good to know, thanks!
Also means I should change the timing belt on my '92 Civic VX (1.5L), in service an unknown number of miles. Sounds like a belt break could be catastrophic.
brians356 is offline
Old 07-25-2016, 06:56 AM
  #53
jDmgIrlsb20's Avatar
My car, drove perfectly fine with no problems at all. Drove it about 15 min down the road and shut it off for maybe 5 min. Went to turn it back on and it just cranked and cranked and wouldn't start.
I tried to pop start it and it did something really strange, like almost tried to start but didn't, not sure how to explain what it did. Almost like puffing.
Tried jump starting it and still only cranked and didn't start.
So i added oil just to be safe.
I can hear the fuel pump prime, but it doesn't seem like it is getting fuel.
I say this because when we tried using starter fluid, it tried to start (puffing and sputtering) and then shut right back off instantly. Almost as if it was not getting fuel to stay running.
I understand this may be a stupid question, does anyone have any ideas because i am being told it is the fuel pump, but if i can hear that prime is that possible?
Thanks
jDmgIrlsb20 is offline
Old 07-25-2016, 07:35 AM
  #54
Former User's Avatar
^Please create your own thread.
Former User is offline
Boosted96gsr
01-09-2012 08:04 PM
Ek9_Cuhzz
58
01-07-2011 04:54 AM
juevi (old)
03-15-2007 04:29 AM
GoldCoin
08-21-2006 06:29 PM
skata89
05-21-2006 03:32 PM
Quick Reply: *** The BASICS: No Start Diagnosis 101 ***
