"Loopy Idle"
Old 02-15-2006, 06:28 AM
Terrance's Avatar
Default "Loopy Idle"
I always hear people talking about a loopy Idle.
What exactly does this mean?
What causes loopy Idle?
Internal? vacuum? etc
Old 02-15-2006, 08:00 AM
BiffStroganoffsky's Avatar
I think they are talking about the instance where the car revs up and down without any input from the driver. One soler had this happen with his vehicle and it was tracked down to a vacuum valve (can't remember the exact name of the part) being dirty...we think.
Old 02-15-2006, 08:11 AM
Soccerking3000's Avatar
Default Re: (BiffStroganoffsky)
yea its usually the IACV that gets dirty and will cause this. Also there are vaccuum leaks. Some people also use that term with aggressive cam shaft and how they idle...
Old 02-15-2006, 01:52 PM
schardbody's Avatar
if you mean "lopey" idle then they are referring to how smooth the idle is, most of the tire you hear this in referrance to camshafts, manufacturers will say "slight lope", "close to stock", "mild lope" etc.....
Old 02-15-2006, 05:34 PM
Terrance's Avatar
Default Re: (schardbody)
Yeah mine gets alil loopy at start up only. when its warmed up its good.
Usually shifts from 1500 to 1200 every 1-2 seconds or so
so this is a dirty IACV??
Old 02-16-2006, 12:20 AM
blucivicSl
Guest
Posts: n/a
Default Re: "Loopy Idle" (Crayon)
this should help:
https://honda-tech.com/zerothread?id=1003988
simon.vada
09-23-2018 04:42 PM
Run Away
03-11-2006 05:08 PM
Quick Reply: "Loopy Idle"
