Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Aftermarket seats???
Old 06-10-2015, 06:39 PM
DaveSi677's Avatar
Default Aftermarket seats???
Question here... anybody has installed aftermarket seats?
I'm looking to upgrade my seats to an aftermarket seat either a Corbeau or Sparco and cause the airbag connector will be disconnected I'll have that dash light on.
So wondering if anybody has tried this to resolve the problem?
AirBag Resistor Kit
Old 06-11-2015, 05:00 PM
97emsedan's Avatar
Default Re: Aftermarket seats???
good luck with that...might have to rig up a shunt or something..
Old 06-11-2015, 09:26 PM
DaveSi677's Avatar
ya I'm looking into it I'll see what I can come up with... I know a few guys I have used some sort of resistors but was wondering if I could just skip that and get the kit instead if it works.
Old 06-12-2015, 04:41 AM
junkyard racer's Avatar
I didn't even think of the seat air bag.
What rail are you going to go with? I wish I could find a low position seat rail for my factory seat.
Old 06-12-2015, 06:15 PM
Hites's Avatar
What year & trim? Sedan or coupe?
I might be able to design you something.
Remind me on Monday, and I'll look into it.
Old 06-13-2015, 02:39 AM
14 Si sedan
Old 06-13-2015, 05:56 AM
He knows where you live!
TheMuffinMan's Avatar
Jesus christ that's not worth $75.
That's probably like the airbag/steering wheel resistor I did up in my Accord. It's a ~2ohm resistor and that's it. It costs *maybe* 10 cents if you buy like 10 of them.
I'd recommend getting a multimeter and figuring out what the airbag's resistance is, then you can just slap on a resistor of the same amount and the car won't be aware of the change. There's a DIY/Guide in the Accord FAQ on how to do it for your 94-97 Accord I wrote up.
Old 06-13-2015, 09:29 AM
Bwill9886's Avatar
I noticed a little while ago that ProCivic had Sparco seat bases and Buddy Club seat rails specifically for the 9th gens if you haven't seen that. Didn't look at part numbers.
No one on the other forums has tested the resistors on the 9ths yet. You'd think it would be the same for both gens, but I guess we will see.
Like TheMuffinMan said though, the price on that kit is all labor and profit... If it's worth that much to you to not make your own, go for it. Otherwise it can be done much cheaper.
Old 06-13-2015, 09:46 AM
DaveSi677's Avatar
You do make a valid point Muffinman... I believe from some reading I did before posting you only need 2.5ohm resistor. Seems like some of the guys ran into some issues with matching up.
Old 06-16-2015, 11:26 AM
Yep, I did it in the Accord and never had an issue with it. Disconnected the SRS harness for the airbag, slapped in the resistor (had the battery pulled for awhile beforehand), then sealed it up. Because I had driven it without the resistor I had to go through the SRS reset procedure but didn't take more than 30 minutes to do it.
Old 06-24-2015, 06:48 AM
rd2smoker's Avatar
Yeah im 6'3" and made a set of rear drop brackets for the stock seats, basically drill out the OE heat-press rivets and replace the drop brackets with a flat peace of 1/4" steel, drill a hole for the floor bolt and weld or bolt the new bracket to the seat. I weldid it. Seems to take more time to take it out than to do the mod. Drops the back about 2.5" and bends the knee a bit which is nice cus OE seems a lil flat.... car feels soooo much bigger now. Cost is zero if you have some short 1/2" nuts/bolts and some scrap steel.
Old 06-24-2015, 06:50 AM
rd2smoker's Avatar
^ I found you can only go about a inch lower in the front due to the sub floor bracing so I just stuck with the back.
LoNsloEk
10-25-2012 12:16 PM
ReV LiMiT
12-19-2010 12:19 PM
dk4ever
01-26-2009 09:58 AM
s2kDinesh
Honda S2000
10
01-17-2005 05:11 PM
Quick Reply: Aftermarket seats???
