Wiring Diagram for 2008 Honda Civic SI 4 Door Sedan - Honda-Tech
Old 05-21-2008, 04:56 AM   #1
jschaff's Avatar
Default Wiring Diagram for 2008 Honda Civic SI 4 Door Sedan
I am needing a wiring diagram for the 2008 Civic SI so that I can install my siren. For example, there are wires for the following:
Hands Free Inputs (connects to the Horn Ring Circuit) used to toggle siren sounds from the horn switch instead of having to reach over and do it on a switch box.
Backlighting - connects to marker light circuit ?
Park Kill (will kill siren when you put the car in park - not sure how that would work with a manual trans) - connects to the neutral safety switch signal wire.
A wire to connect to a low current system switch - not sure what they are talking about here.
Here is a link to the installation guide of the siren.
http://www.sirennet.com/pdf/14...m.pdf
THANKS AGAIN EVERYONE
jschaff is offline   Reply With Quote
Old 05-21-2008, 07:52 PM   #2
Default Re: Wiring Diagram for 2008 Honda Civic SI 4 Door Sedan (jschaff)
Why install a siren on a brand new car? You are going to void any warranty on anything associated with the wiring you have to splice into. Honda does not like modifcations on there cars espically wiring
MustangLX6.0 is offline   Reply With Quote
[FAQ-DIY] OEM 5G 92-95 Civic Security Systems and Keyless Entry deschlong Honda Civic / Del Sol (1992 - 2000) 8 04-04-2015 05:23 AM
Simple question regarding gauge wiring...Need some help VI Boost Audio / Security / Video 7 02-15-2010 01:02 PM
Fishing wires thru the firewall on a 2008 Honda Civic SI - Siren Related again - sorry jschaff Honda Civic (2006 - 2015) 4 05-24-2008 06:36 PM
your thoughts on siren problems. PariahBoardshop Audio / Security / Video 2 08-09-2004 04:04 PM
Q! about DEI 513T Mini Piezo siren Fuster_Cluck Audio / Security / Video 6 08-10-2003 07:25 AM
Tags
06, 2007, 2008, accord, civic, del, diagram, electrical, honda, neutral, radio, safety, schematics, sol, switch, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
