Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
DIY on installation and removal of Valve Cover
Old 12-23-2007, 09:04 PM
dt98gsr's Avatar
Default DIY on installation and removal of Valve Cover
I am having my valve cover powder coated some time over the next week or two and I haven't taken it off of this car before.
I have a general idea of how to do it, and replaced my VC on my GSR but I was wondering if anyone knew of a DIY or could offer some helpful tips/advice?
There is a DIY on 8thcivic but its kind of brief and the pictures have been deleted from the post.
Old 12-23-2007, 09:17 PM
dt98gsr's Avatar
Default Re: DIY on installation and removal of Valve Cover (dt98gsr)
it looks like I should remove the cowl (the black plastic piece with the windshield washer sprayers) and then remove a heat shield which is below that to get easier access to the VC.
Old 12-24-2007, 08:43 AM
exhaust_note's Avatar
better
https://honda-tech.com/zerothread?id=1932651
Old 12-24-2007, 12:16 PM
06siracer's Avatar
Default Re: (exhaust_note)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exhaust_note &raquo;</TD></TR><TR><TD CLASS="quote">better
https://honda-tech.com/zerothread?id=1932651</TD></TR></TABLE>
that doesn't tell u how too get the thing off just what a before and after looks like.
Old 12-24-2007, 03:26 PM
Caveman74's Avatar
Default Re: (06siracer)
3 tabs that hold the cowl on then Pop the plastic cowl off, be carefull on it. there are 5 bolts that hold the metal under the cowl. once those are taken off, pull off that peice and then undo the bolts to the valve cover
Old 12-24-2007, 03:33 PM
dt98gsr's Avatar
yeah I saw that on 8th civic, blue used the DIY on 8th, before the pictures were taken down. But thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 06siracer &raquo;</TD></TR><TR><TD CLASS="quote">
that doesn't tell u how too get the thing off just what a before and after looks like.</TD></TR></TABLE>
x2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Caveman74 &raquo;</TD></TR><TR><TD CLASS="quote"> 3 tabs that hold the cowl on then Pop the plastic cowl off, be carefull on it. there are 5 bolts that hold the metal under the cowl. once those are taken off, pull off that peice and then undo the bolts to the valve cover
Thanks, sounds fairly easy.
jbell
Honda S2000
16
09-18-2008 06:26 PM
civicshowracing65
10-20-2004 03:13 PM
Hazem
29
10-01-2004 12:16 PM
-anakist-
05-29-2004 02:50 PM
Edwin
07-24-2002 12:15 PM
Quick Reply: DIY on installation and removal of Valve Cover
