Question for Civic EX service code?? - Honda-Tech
Old 11-14-2008, 07:34 AM   #1
Plastic Fury's Avatar
Default Question for Civic EX service code??
I tried searching but I keep getting a "search server is down" message. I have an 06 Civic EX that I have done all the maintenance on (as I do with all my cars). I was on the way home and got the service wrench, no big deal the oil is at 15% so I will change it this weekend but I also got a B12 code?
I see in the service manual it lists an A and B code section but I see no mention of 12, anybody have any idea on this one?
Plastic Fury is offline   Reply With Quote
Old 11-14-2008, 08:30 AM   #2
smxcan's Avatar
Default Re: Question for Civic EX service code?? (Plastic Fury)
B12 is not a B-twelve, it's actually a B-one-and-two. So you would follow the maintenance sub items for 1 and 2.
The following are from the 2006 Civic Sedan Owners Manual (p.187):
Symbol A:
- Replace engine oil
Symbol B:
- Replace engine oil and oil filter
- Inspect front and rear brakes
- Check parking brake adjustment
- Inspect these items:
- Tie rod ends, steering gear box, and boots
- Suspension components
- Driveshaft boots
- Brake hoses and lines (including ABS)
- All fluid levels and condition of fluids
- Exhaust system
- Fuel lines and connections
Number 1:
- Rotate tires
Number 2:
- Replace air cleaner element
- If you drive in dusty conditions, replace every 15,000 miles (24,000 km).
- Replace dust and pollen filter
- If you drive primarily in urban areas that have high concentrations
of soot in the air from industry and from diesel-powered vehicles,
- Inspect drive belt
Number 3:
- Replace transmission fluid
Number 4:
- Replace spark plugs
- Inspect valve clearance
Number 5:
- Replace engine coolant
HONDA OWNERS MANUALS: https://techinfo.honda.com/rja...L.asp
smxcan is offline   Reply With Quote
Old 11-14-2008, 11:37 AM   #3
Default Re: Question for Civic EX service code?? (smxcan)
I had a feeling it was just for the two sub boxes listed in the manual, as in B 1 & 2 but I wanted to double check and make sure I was not missing something.
Thanks.
MM code changing on its own genuser Tech / Misc 2 03-01-2015 11:46 AM
90K service questions sokoloff Honda Civic / Del Sol (1992 - 2000) 5 10-16-2005 07:06 AM
CEL code 22? reaction360 Tech / Misc 8 09-23-2003 02:00 PM
Check engine light?! CODE 32?!?! reaction360 Tech / Misc 5 05-10-2003 04:53 PM
ECU self-diagnostic Cynical 1 Tech / Misc 5 09-29-2002 05:24 PM
Tags
06, 12, 2006, 2008, b12, canada, cicv, civic, code, codes, engine, honda, maintenance, odyssey, service
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
