Power steering pump whining after fluid change
OK, so I decided to be a good Civic owner and change my PS fluid even though nothing was really wrong with it. Now I'm regretting it. First of all, I followed the service manual exactly and ran the lines completely dry. I then filled the reservoir to the MAX line, started the car and started turning the wheel side to side. It was whining pretty bad a first but then got quieter. The problem is it's still whining when idling and accelerating. Do I have trapped air? I did this last weekend and just went out there today and removed the fluid from the reservoir to try to bleed the lines again. I'm at a loss as the whine isn't going away. Did I damage the pump when running it dry for a minute the first time? Is there a better way to bleed the system? Thanks for any help!
Re: Power steering pump whining after fluid change
I just wanted to update everyone that I know someone that works for a Honda dealership, and he asked the shop foreman about my issue. He said it's definitely air that's stuck in there, so what they usually do is run the car, turn the wheel all the way to one side, then turn the car off like that and leave it for 20 minutes or so. Then turn the car on, turn the wheel all the way to the other side, shut the car off, wait 20 minutes, repeat as needed. I'll let you know if that works out.. good info. to know.
You would be way better off if you just sucked out as much of the fluid you could, then refilled it and did that a few times over a weeks or months time.
My tool or choice is a large enema syringe from the drug store, I have had the same one for at least 5 years, it works great on master cylinders and power steering.
Letting it sit for 20 minutes is key. If you continue to run it and turn Lock to lock you keep foaming the foam so to speak. Let it sit and the bubbles will eventually collect and dissipate.
Did you use OE Honda fluid?
Since I got home today, I've been turning the wheel to one side, turning the car off, letting it sit 20 mins, same for other side, etc. for like 3 hours... it sounds the same, maybe even worse. The steering is silky smooth so it's not like the pump is dead, you know? What could I be doing wrong?
Sorry, yes, I definitely used OE fluid. My neighbor, a certified mechanic, came over to see what was up. I told him, and he said "man, go get some of that Lucal synthetic fluid and put it in there". I said no, you have to put OE fluid. He said "no man, it works on EVERYTHING. I put it in my Pilot when I had it." I said oh, ok... NOT!
Ok, good job on the OE fluid. I've seen many of those pumps go bad using either AT fluid or local parts store fluid. If the fluid is at the FULL mark ad first look foamy, wait instill the morning and see how it sounds. If its still lOud tomorrow, listen to the pump with a screw driver like its a doctors scope, could be bearings. Let's hope not!!!
Ignorance is bliss. Tell them it was making noise and you just added fluid. If they catch wind of you tinkering around, you're SOL my friend.
Oh no, I wasn't about to tell them I caused it. LOL It actually seems to be getting better since parking with the wheels turned all the way and letting it sit for a while. We'll see how much better it does tomorrow. There must have been a ton of air in there.
Nothing to add on the subject of this thread. But what i used is a shampoo pump dispenser. Take it apart. And pump directly back into the bottle.
91_accordwagon
01-30-2011 07:48 PM
AccordEX1991
Honda Civic (2001 - 2005)
08-12-2009 02:17 PM
svarver
02-25-2004 09:37 AM
