Piston won't retract-2006 Honda civic - Honda-Tech
Old 02-16-2017, 06:52 AM   #1
Default Piston won't retract-2006 Honda civic
Hello, I have an issue. Just completed a build, and I'm trying to drive it to make sure everything is good...well when I attempt...it feels like my brakes are always on. So I have think I either have a seized piston, causing it not to retract. However, the first time this happened I took the caliper off and compressed the piston back with a c clamp..so I thought maybe it wasn't it...but anyways can someone give some clarification? It will be greatly appreciated. It is both wheels, they will not turn freely when jacked up.
If holmesnmanny reads this, I got the car started, my dumb self didn't plug something in...so I just wanted you to know that I wasn't ignoring your advice.
ccoake1 is offline   Reply With Quote
Old 02-17-2017, 03:58 AM   #2
Default Re: Piston won't retract-2006 Honda civic
if you use moly grease on the slide pins it will make the lower sliding pin bushing swell up and lock up the slide pin
you only should use SilGlyde or equivalent type of silicone grease on slide pins, especially those with the small bushings as those that go on slide pins.
holmesnmanny is offline   Reply With Quote
Old 02-17-2017, 08:51 AM   #3
holmesnmanny what you are saying is I should check slide pins....
Old 02-17-2017, 11:18 AM   #4
yes
Old 02-17-2017, 01:52 PM   #5
Okay so new angle, still haven't checked the pins...but however, when I got home from work I jacked up the car and the tires were still not moving, I doubled checked the wheel...no spin. So I loosened a line on the master cylinder and the driver side tire freed up. I will still check the slide pins....
I think i did some damage on my rear brake caliper Crispypata Suspension & Brakes 2 01-15-2017 05:55 AM
Rear brake piston keeps spinning... gsrob Acura Integra 2 05-20-2016 05:03 AM
Honda CRV Brake question hondadadcrv Honda Element & CR-V 1 07-10-2010 03:05 PM
'97 Civic Brake Help Syndacate Honda Civic / Del Sol (1992 - 2000) 17 05-11-2010 08:20 PM
replacement antenna mast sticks out a little ttcheung97 Honda Accord (1990 - 2002) 1 09-14-2009 05:34 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
