Official HPDE/Time Attack/Racing Thread - Page 2 - Honda-Tech
Old 08-29-2014, 10:55 PM   #26
El Presidente
DaveSi677's Avatar
Default Re: Official HPDE/Time Attack/Racing Thread
I don't know which with pod style to go with yet lol
DaveSi677 is offline   Reply With Quote
Old 09-05-2014, 03:56 PM   #27
junkyard racer's Avatar
Does anyone know how wide the factory 18" wheel is on a '14 Si?
junkyard racer is offline   Reply With Quote
Old 09-06-2014, 10:44 AM   #28
97emsedan's Avatar
7.5"
97emsedan is offline   Reply With Quote
Old 09-06-2014, 02:39 PM   #29
El Presidente
DaveSi677's Avatar
7.5"
Can't wait tomorrow is another track day!
Old 09-09-2014, 12:28 PM   #30
El Presidente
DaveSi677's Avatar
I'm editing a video my friend has of me... He was in his Type-R following me.
I'll post it soon!
Old 09-09-2014, 12:55 PM   #31
Thanks and sweet!
Old 09-09-2014, 02:00 PM   #32
El Presidente
DaveSi677's Avatar
no problem are you planning any track days?
Old 09-09-2014, 05:15 PM   #33
Gingerman on the 26th and I hope to get an auto-x in before years end also!
Old 09-10-2014, 12:36 PM   #34
El Presidente
DaveSi677's Avatar
nice that is sick!
Old 09-25-2014, 02:38 PM   #35
El Presidente
DaveSi677's Avatar
So had to replace the top hat and the bearing yesterday. They were squeaking and making some annoying noises also the suspension in the front felt a very off in terms of stability.
I didn't have enough time to do some reach in terms of what is better as aftermarket so I got OEM ones and install them.
I needed an alignment and decided to go a little more aggressive this time for our last team track day.
Front camber is -3.0
Rear camber is -2.0
Toe is set at 0 since I still drive it on the street.
One tip that was given to me is to spray the top plate area with some WD-40 as this help it from failing and seizing. Also the rust will come out too.
Old 10-01-2014, 07:54 AM   #36
El Presidente
DaveSi677's Avatar
So I finish working today and I'm off till the end of the weekend...
So I got this planned EM1 CMC and doing my brakes. Will also change the tranny fluid.
Also a quick look around and clean up in the engine bay.
Saturday full track day!
Old 10-13-2014, 04:06 PM   #37
FalkenSiR's Avatar
Good stuff man. What ss brake lines are you using?
FalkenSiR is offline   Reply With Quote
Old 10-16-2014, 03:09 PM   #38
El Presidente
DaveSi677's Avatar
Ended up using Goodridge SS lines.
Works great!
Old 10-21-2014, 03:56 PM   #39
I'm in the process of prepping my 2013 FB6 for some track/hill climb/autox time next season... A few things of note before my questions:
1 - I'm running an aftercooled CT-e setup, putting down around 248ft/lbs and 305hp.
2 - Going to be putting in a custom Koni-based coilover setup from Redshift this fall/winter.
3 - Going to be putting in Hondata TC this fall/winter.
4 - Considering running either r-comp or maybe more an auto-x style tire (such as an ad08r)... Not sure yet, I'm only doing track stuff for fun, not too concerned about being competitive, but I can say for sure my factory all-season tires aren't any good for track days!
The questions... I'm considering the fact I'll be pulling much higher g force after the suspension and tires, so thinking I should perhaps consider a baffled oil pan, maybe higher capacity/oil cooler, and oil pressure/temp monitoring. Anyone have any opinions about those things and any solutions for a 9th civic? Also, this is my driver, so I'm trying to not over complicate it, but I may already be too far down that road! ;-)
EDIT: Oh, also, with the aftercooler, it isn't like I have a lot of room for another cooler core (for oil cooling)... Something to consider anyhow...
dath1974 is offline   Reply With Quote
Old 10-21-2014, 04:46 PM   #40
El Presidente
DaveSi677's Avatar
If you go with R compound tires you will need to have either a baffled oil pan and a catch can also.
I'm in the middle of looking into it... I will say this for the oil catch can there are no kits for it you have to piece it out.
For the baffled oil pan I would go with Moroso is the best option out there.
Oil temp gauge is also a good idea also will be getting one over the winter for next season.
Old 10-21-2014, 05:03 PM   #41
I would love to see some build threads for those of you who are building a 9th gen!
Old 10-22-2014, 03:54 PM   #42
Thanks, that backs up what I was already thinking. Regarding the catch can, I'm presuming you mean on the crankcase where the PCV is normally and not the valve cover? Or is there enough oil movement in both places to need a can? I was already considering the PCV side just to keep my aftercooler/intake clean... Also not to worried about buying a catch can and installing, the difficult part is figuring out where to mount it and understanding the theory/application, the rest should be pretty simple...
And not to be contrary since I did ask for advice, but I've seen some mixed reviews about Moroso pans sealing well. What's your opinion about picking up (or fabbing) a weld-in kit with a factory pan?
So what if I stuck to tires more like the RE-11a, ad08r, or ZII? You think the same things still apply, or it's not such a big deal?
Thanks!
Old 10-22-2014, 03:56 PM   #43
Quote:
I really should start one somewhere... I just have this thing with finishing something before I take pictures/etc...
Old 10-29-2014, 11:13 AM   #44
El Presidente
DaveSi677's Avatar
If you stick with ZII or Re's or Ad's you should be fine... but I would still do a catch can regardless! I rather play it safe tbh.
I'll ask a few of my track buddies what they think of the Moroso pans they all have Kswaps so the information should be useful enough for the both of us.
Old 10-30-2014, 10:20 AM   #45
Teg24's Avatar
Nice to see a track thread in here. Going back to your oil starvation, baffled pan questions. I ran into quiet a bit of oil starvation issues back in July when I was at Road America. (07 Civic Si Coupe) Faster track, higher speeds while cornering. I didn't notice too much though while I was at Mid Ohio. I plan on sending my oil pan off to Tracktuff for a baffled pan and modified oil pump. He shaved and modified my RBC. Great company to work with. Anyone else in the SE region? Planning on Road Atlanta December 6,7th? Heres a picture of my turd
Teg24 is offline   Reply With Quote
Old 10-31-2014, 04:16 AM   #46
El Presidente
DaveSi677's Avatar
A lot of people are using the A2 oil pump. I still haven't made the change yet but will probably have to at some point. Also going R compound tires will help cause oil starvation as the cornering speed with be much great so the force of movement will also.
Glad to see you track your car also!
What do you have done?
Old 10-31-2014, 05:22 AM   #47
Kimsey099's Avatar
What size wheels you guys running on the cars ? I was figuring once I get my new 4dr si that I would want 17in wheels for the track. Curious to hear what you guys use.
Here is my current track beast though
Kimsey099 is offline   Reply With Quote
Old 10-31-2014, 07:08 AM   #48
El Presidente
DaveSi677's Avatar
I'm running 17 x 7 stock wheel right now but moving to 17 x 8.
For the time attack series I'm participating in the max wheel size we can use is 17x8 and max tire size is 225.
I'll be using the RPF1 since they are light, durable and cheap to replace.
Old 10-31-2014, 10:46 AM   #49
Kimsey099's Avatar
Great Minds think a like , that's what I was planning on , to bad they don't make 6UL wheels in 17in anymore. That oils have been nice to run as well.
Old 10-31-2014, 01:23 PM   #50
tirerack.com
I don't disagree that it is light and durable, (they are using the same technology in this wheel as they are in the F1 wheel) but dont forget about the new Advanti Racing HY Hybris wheel. Its also light, flow formed and very affordable. -though only offered in 7.5" width. In a 17x7.5, its $155.
__________________
AJ | Tire Rack
7101 Vorden Parkway
South Bend, IN 46628
aj@tirerack.com
1.800.428.8355 ext 4066
Support Honda-Tech!!!
AJ@tirerack.com is offline   Reply With Quote
Progress Coil-over Special Promotion Progress Technology Wheels, Tires, Brakes, and Suspension 3635 03-23-2017 12:11 PM
FS: New Ingalls Rear Camber Kit 38725 for Accord, TSX, RL & TL 94eg! For Sale 5 05-24-2016 08:46 PM
Help decipher my alignment sheet bb_one Suspension & Brakes 3 04-18-2009 04:02 PM
Alignment Question after lowering car .brian. Acura Integra 18 01-17-2006 10:35 AM
Alignment settings .E Suspension & Brakes 4 12-04-2005 08:34 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
