Are my coils fried?
Are my coils fried?
Are these ignition coils cooked? Sorry if the pics are huge (pics at the bottom).
I've been having problems recently on my 2012 Civic (150,000 miles):
Weak acceleration, lack of power when accelerating, car shaking when idle / stopped, slightly louder engine noise.. sometimes when starting the ignition it sounds like it's not gonna start but does.. but 90% of the time it starts right up.. never had a "no start" condition.
Never had a check engine light and no codes are stored at all.
I found a tear in my air intake boot directly after the MAF and replaced it thinking this could be causing some problems. The problems seemed to get better for a day but they're back now.
I replaced all four spark plugs with brand new ones, no luck. But when doing this I noticed all four ignition coils had this identical appearance.. brown soot all over them. Obviously it doesn't look good but is it really cause for concern?
I did a spark test using a spark tester (AutoCraft Ignition Tester) and all four coils had the same result-- there was a spark although it looked weak. Very very thin, thinner than a strand of hair, and white. The spark wasn't consistent though, sometimes it would seem like 4-5 sparks per second, then 3-4, then back to 4-5.
Any ideas? Is it worth replacing coils or should I check elsewhere first?
I heard it could be my battery (need to replace it soon anyway) not sending enough voltage to the alternator, which could be creating a weak spark? Thus why there is no CEL, because it's a spark but very weak..?
P.S. it looks like oil all around the dipstick but it's just dirt, pics are deceiving.
Thanks!
Thanks!
Re: Are my coils fried?
Thanks
I don't think the battery is bad unless he was in extreme cold or heat. The average battery last 5 years. Again that's a lot of miles. I think a tune up should help him. Make sure you filters are changed also.
Pretty impressed you did that many miles in that short amount of time. My car is a 06 and I just hit 161k today.
sethmoman
12
12-28-2011 10:00 PM
