Honda Fluids vs others - Honda-Tech
Old 10-27-2009, 04:10 AM   #1
Default Honda Fluids vs others
hey guys, I'm about to do a brake fluid change, change my mtf, and top off my other fluids. Do you think that Honda fluids are really "better" then lets say some other companies?
Jordanasm is offline   Reply With Quote
Old 10-27-2009, 06:16 AM   #2
Default Re: Honda Fluids vs others
Quote:
Here is my view based on years of owning Hondas:
Brake fluid -- any high quality aftermarket brake fluid is fine.
Hydraulic clutch fluid -- see brake fluid above.
Manual transmission fluid -- Honda OEM bought from dealer. I would not rule out some of the recommendations for other MTFs here, though. I would never use motor oil in the transmission; use of motor oil is outdated due to industry changes in motor oil additives.
Power steering fluid -- aftermarket stores like Autozone, Pep Boys and Napa sell a Honda specific PS fluid that is fine. Just make sure the aftermarket fluid container says it is for Hondas. Failing to get the Honda specific fluid can destroy the seals on the PS system.
Coolant -- either Honda OEM or orange Havoline Dexcool. The Dexcool says it is specifically designed for aluminum yada engines requiring yada. I have been using the Dexcool since 2002. I buy the undiluted version and then add distilled water. Do not use tap water.
Engine oil -- any good motor oil appropriate to the age of the engine is fine.
honda.lioness is offline   Reply With Quote
Old 10-27-2009, 08:05 AM   #3
^ thank you.
Old 10-27-2009, 08:54 AM   #4
CerealKiller's Avatar
Very well put.
CerealKiller is offline   Reply With Quote
Old 10-27-2009, 11:31 AM   #5
New User
I'll always use Catrol 5 30 or 5 30 highmileage
djblive is offline   Reply With Quote
Old 10-27-2009, 04:41 PM   #6
I believe amsoil fluids are much better than OEM fluids. Go to their site and look at the specifications for the fluids. The temperature thresholds and most of the results from the tests prove them to be better.
Honda is not a fluid company, Amsoil, Royal Purple, Castrol, etc. are
The test results that AMSOIL displays are by third party I believe.
ajpturbopittsburgh is offline   Reply With Quote
Old 10-29-2009, 05:37 AM   #7
Retribution's Avatar
Honda doesn't make their own fluids, the fluids are made by fluid companies and put in a bottle that says honda.
Retribution is offline   Reply With Quote
Old 10-29-2009, 07:53 AM   #8
Occupy GDD
Alex_G's Avatar
For most drivers off the shelf fluids will allow your vehicle to last a long time. If you plan to drag/auto-x/boost your vehicle AMSOIL fluids would be an excellent choice.
Alex_G is offline   Reply With Quote
Old 10-29-2009, 04:34 PM   #9
ChargedSI's Avatar
Quote:
I would agree. If your not slamming the motor for gross performance, OEM fluid would be just fine and save you a ton of money.
ChargedSI is offline   Reply With Quote
Trans fluid change? bmclean1 Honda Accord (1990 - 2002) 4 02-24-2011 09:03 PM
Auto Transmission Fluid Firefoxracer Acura TL, RL & ZDX 2 08-19-2008 12:06 PM
Brake fluid/and brake bleeding kornerk12 Honda Prelude 14 12-30-2005 01:53 PM
good mechanics in so. cal eMpAtHy General Discussion and Debate 2 02-16-2005 10:20 PM
Changing Tranny Fluid? onyx00 Acura Integra Type-R 8 10-27-2001 08:56 AM
Tags
1993, accord, acura, brake, buy, dexcool, fluid, fluids, honda, mtf, oem, others, recommendation, rsx, tech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
