Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
help help !Turn signals come up when braking
Old 01-17-2015, 03:13 PM
m.mobarrez's Avatar
Default help help !Turn signals come up when braking
Hello all,
Help Needed, when I press on the brake the front/rear turn lights would light up along with the brake lights in the back... and when you turn the turn signal lights on without the brake pressed they work fine, but if you press the brake well they are blinking they will stay on solid and bolth turn lights in the cluster light up also...
Also, I was driving in the highway and I noticed that when it is on cruise if I turn the turn signals on the cruise control is deactivated !
I had a mechanic to take a look at it and he told me the fuse box needs to be replaced ! What is your idea?
Thanks
Old 01-17-2015, 03:38 PM
Global Moderator
tech8's Avatar
Default Re: help help !Turn signals come up when braking
What year, model, 2 or 4 door, etc.?
Old 01-17-2015, 03:42 PM
m.mobarrez's Avatar
It is a 2009, Honda civic, sedan LX-S.
Old 01-19-2015, 10:13 AM
m.mobarrez's Avatar
Did anyone have the same problem? it is really annoying, I have shown it to another mechanic today he said it is not the fuse box and he couldn't figure out what the problem is !!
Old 01-19-2015, 10:58 AM
Global Moderator
tech8's Avatar
Issue may possibly be a short at one of the following:
- MICU (built into the under-dash fuse/relay box).
- wires running along the left side harness or at a 14-P white connector behind the left C-pillar. Wires for the brake light circuit and the rear turn signal light circuit may possibly be touching and back-feeding the turn signals.
Old 01-19-2015, 11:09 AM
m.mobarrez's Avatar
Thank you tech8
If the problem is MICU, Do I need to replace the whole fuse box? if yes, can I do it myself? I was searching for that on internet some say programming is needed !?
I greatly appreciate your help.
Old 01-20-2015, 09:08 AM
m.mobarrez's Avatar
bump
Old 08-30-2022, 08:23 PM
Ronaldorpl's Avatar
Hey did you figure out what the problem was, I'm having the same issue.
Old 08-30-2022, 08:28 PM
Ryanthegreat1's Avatar
Any chance you have installed LED bulbs in the taillights?
Old 08-31-2022, 03:59 AM
Ronaldorpl's Avatar
I don't think so but I do have LED in my park and ID lights. Could that cause it?
Old 08-31-2022, 08:52 PM
Ronaldorpl's Avatar
Yes I confirmed that a have led bulbs in the taillights on the trunk lid. What should I do?
Old 09-01-2022, 06:06 AM
Remove the LEDs and see if the problem goes away.
Old 09-01-2022, 06:12 AM
Ronaldorpl's Avatar
OK thanks will try it out today
KRAP DIVAD
11-28-2009 06:44 AM
nwl
08-09-2008 03:57 PM
danny420
04-04-2008 07:06 PM
CrazyRexBoy
01-13-2007 07:14 PM
jdmaccordh22
03-18-2003 06:07 PM
Quick Reply: help help !Turn signals come up when braking
