Gauge cluster and fan problem - Honda-Tech
Old 03-01-2017, 01:40 PM   #1
Default Gauge cluster and fan problem
Have a 2008 honda civic. Car will start. In start up the gauge cluster goes through the check process then the temp gauge goes out. The check engine, abs, doors open, and TPMS lights are on. And the tach and speedometer are not working. Also the radiator fans do not come on. Tried two code readers and both say can not communicate.
any ideas?
Josephsnodgrass is offline   Reply With Quote
Old 03-02-2017, 01:59 AM   #2
Default Re: Gauge cluster and fan problem
It might be wise to go see a local electrical specialist on this one.
holmesnmanny is offline   Reply With Quote
Old 03-02-2017, 06:04 AM   #3
Moderator
tech8's Avatar
The Gauge Control Module (instrument cluster module) is not probably not communicating with the PCM (power train control module).
Disconnect the negative battery cable for several minutes, to reset the modules and see if that makes a difference.
tech8 is offline   Reply With Quote
Old 03-02-2017, 01:57 PM   #4
Disconnected battery overnight. No change. Where is the gauge cluster control module. I'm sure something is fried. Just not sure if it's the pcm since car will start. Don't think the gauge cluster itself is messed up cause it does the lamp check process just fine
Strange overheating problem tenelson Honda Civic / Del Sol (1992 - 2000) 7 08-24-2010 08:04 AM
Gauge cluster has a mind of it's own?? hatch_kidb18b1 Honda CRX / EF Civic (1988 - 1991) 11 04-01-2010 12:10 PM
gauge cluster help!!! dohcgarage@714 Acura Integra 2 01-03-2008 05:31 PM
Radiator Fan rein1116 Acura Integra 3 05-18-2007 06:45 PM
temperature gauge goes to H, not overheating, HELP! cthan3o3 Honda Civic / Del Sol (1992 - 2000) 7 07-26-2005 09:48 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
