DIY: Reset your Oil Life Meter - Page 3 - Honda-Tech
Old 12-03-2011, 05:57 PM   #51
DCSportEJ1Civic's Avatar
Default Re: DIY: Reset your Oil Life Meter
Should probably note in the OP that it's not really and oil life, but a maintenance reminder. It schedules other things such as trans fluid, brake service, ect. Resetting the maintenance reminder this way resets all of it, not just oil life.
DCSportEJ1Civic is offline   Reply With Quote
Old 02-06-2012, 08:07 AM   #52
Just gatta make sure the cars not moving when you do this
ruggierosi16 is offline   Reply With Quote
Old 03-23-2012, 07:40 AM   #53
yea
larry diggs is offline   Reply With Quote
Old 08-05-2012, 05:45 AM   #54
So driving 95% highways....what mileage / oil meter life did you change out at?
fsujunkie850 is offline   Reply With Quote
Old 08-14-2012, 08:09 AM   #55
I have a 11 month old insight with 11,000. miles just took it in for 1st oil change. the oil life meter was at 10%. I drive like a granny to get the high MPH. The dealer hit me for 59$ four quarts syn. and filter. Still not a bad deal for 11,000 miles only problems the car has had over the year is a faulty tire pressure monitering and a weather seal on the spare tire /cargo access door otherwise a great car
rcnc55 is offline   Reply With Quote
Old 09-20-2012, 10:26 AM   #56
in the owners manual still need pics tho?
Posted from Honda-tech.com App for Android
mattdexter is offline   Reply With Quote
Old 09-21-2012, 10:03 AM   #57
OK, so what do I do if that doesn't work?
I've tried this procedure, exactly as described, 3 or 4 times now.
I've looked on half a dozen message boards and the procedure is always the same. So I know I'm doing it right.
Each time it blinks off after about 10 seconds. And it will stay off as long as I keep pushing on the reset button. But as soon as I release the button, it comes back on again.
I've also noticed it doesn't come on right away when I turn the car on. There is a slight delay, and then it comes on and stays on.
:full disclosure: My car does have the CEL on as well. Can this trigger the "Maintenance Required" light as well?
And maybe this is a question for a different thread, but my "Brake lamp" warning light comes on even though all of my rear lights (yes, even the high-mounted brake light) function perfectly.
Its a 98 Accord Coupe V6 Automatic LX.
nickh2500 is offline   Reply With Quote
Old 10-13-2012, 05:37 AM   #58
That's almost too easy, Thank you!
T_flor is offline   Reply With Quote
Old 11-17-2012, 03:37 AM   #59
Nice post and comments regarding oil meter thank you for the post, can anyone tell me when i need to change oil for my car.
a1alimo is offline   Reply With Quote
Old 12-08-2012, 10:43 AM   #60
nice diy!
klean_txteg is offline   Reply With Quote
Old 12-28-2012, 04:12 AM   #61
Quote:
Originally Posted by axtran View Post
This may be somewhere in the manual, but I could not find it in there (I was kinda too lazy to look) so I just wanted to post it up so people could see and check if they wanted to.
VERY VERY SIMPLE!!
Here goes:
1) Insert Key into Ignition, go to II or "On" position (not "Acc").
2) Hit Sel/Reset until "Oil Life" comes up.
3) Hold for 10 seconds until it flashes.
4) Release
5) Hold again for 5 seconds and then it resets.
Hope this helped someone! It sure was great info for me!
Ha, thank you! I felt like a retard when i couldnt figure it out lol
Alexmn2 is offline   Reply With Quote
Old 03-03-2013, 02:14 PM   #62
Icon2 Re: DIY: Reset your Oil Life Meter
hey ...! 2006 honda civic hybrid
can any body point me to, how to program the IMA. or can I do it through the OBD2 port? I got 100k on my hybrid so I don't care about warenty. and I want more out of my battery. any guidence would be appreciated.
please forgive the spelling. Just a poor old shade tree.
the part that caught my eye was DIY.
expresso1950 is offline   Reply With Quote
Old 07-05-2013, 03:45 PM   #63
Quote:
its recommended to change oil after 5,000 or 6,000 Km of driving, if you changed oil at 120,000 km's your next oil change is at 125,000 or as most new Honda's the oil change indicator lights up and tells you to change oil asap.
Thanks.
avtarhonda2007 is offline   Reply With Quote
Old 02-21-2014, 08:50 PM   #64
VERY VERY SIMPLE!!
Here goes:
4) Release
jessiealicaya is offline   Reply With Quote
Old 02-21-2014, 08:52 PM   #65
Thanks for the info.
Old 02-26-2014, 01:26 AM   #66
Quote:
now explain to me what the information have you got here
Bradleywhites is offline   Reply With Quote
Old 02-26-2014, 08:37 AM   #67
El Presidente
DaveSi677's Avatar
Quote:
Can you explain to me why her explanation is so important for you?
DaveSi677 is offline   Reply With Quote
Old 04-08-2014, 10:06 AM   #68
Mine says change at 15%. I would think anymore is a waste of oil, time and money. Unless your engine is highly modified. But oil is cheap compared to a new engine.
stephenhonda419 is offline   Reply With Quote
Old 05-19-2014, 03:18 PM   #69
It took me a minute to figure this one out! LOL!
AFTurboGirl is offline   Reply With Quote
Old 08-23-2014, 07:37 AM   #70
Thank you so much, I've been looking everywhere for this.
Chaos2003 is offline   Reply With Quote
Old 06-04-2015, 10:07 AM   #71
Icon3 Re: DIY: Reset your Oil Life Meter
Very informative - much appreciated.
Strez is offline   Reply With Quote
Need help with jumpy idle and setting ignition timing Gator417 Honda Civic / Del Sol (1992 - 2000) 5 08-19-2015 08:41 AM
oil reset swegminhas Honda Civic (2006 - 2015) 5 03-24-2015 03:32 PM
2007 Civic oil change / light reset ultimate DIY with pics jt1583 Honda Civic (2006 - 2015) 0 12-07-2010 06:35 AM
Qeustion about 08 Accord Maintenance Minder Sein Honda Accord & Crosstour (2003 - Current) 1 07-18-2009 03:56 PM
how do i reset my oil life on my guages ap2 patricks2000 Honda S2000 6 03-10-2007 12:56 PM
Tags
100, 2005, 2007, acura, civic, fit, honda, life, meter, mileage, oil, reset, reseting, resetting, rl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
