Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
car shakes when brakes are applied!
Old 04-17-2008, 12:44 PM
MUGEN_EG95's Avatar
Default car shakes when brakes are applied!
My friend has an 06 honda civic coupe and everytime he brakes the car shakes violently. I'm just wondering what the cause is. Could it be that his rotors are warped??
Old 04-17-2008, 12:48 PM
FBPSidan's Avatar
Default Re: car shakes when brakes are applied! (MUGEN_EG95)
Very well could be the rotors being warped..how many miles he got? ever had brakes done?
Old 04-17-2008, 12:53 PM
MUGEN_EG95's Avatar
Default Re: car shakes when brakes are applied! (FBPSidan)
he said he got his rotors resufaced a while back and everything was good. Then all of the sudden it went bad again. not sure about milage!
Old 04-17-2008, 01:36 PM
r3vmixman's Avatar
Definetely a rotor problem, possibly an alignment problem too. If your toe is off you can feel vibration on the steering wheel.
Old 04-17-2008, 01:42 PM
Perfectionist's Avatar
It's debatable wether the rotors actually warp, or if the pulsation is due to pad deposits on the rotors surface. Proper "bedding in" of the pads after replacement can minimize the deposit problem. Also very important, whenever remounting wheels, the lug nuts should be torqued to 80lb/ft with a torque wrench in a star pattern to minimize possibly distorting the rotor hub.
Old 04-17-2008, 02:03 PM
gents97civ's Avatar
More than likely he needs some new rotors. I avoid turning rotors, because you reduce the ability of the rotor to dissipate heat. Its usually best to just buy new ones. They are relatively inexpensive, and its a job that any mechanically inclined person can do.
Old 04-17-2008, 04:03 PM
MUGEN_EG95's Avatar
Default Re: (gents97civ)
thanks a whole lot..i'll let him know about the rotors!
Old 04-17-2008, 04:26 PM
zid
zid's Avatar
Default Re: (MUGEN_EG95)
Does he drive it hard? cuz if the pads are hot and you pull over and put the parking brake on thatll just fuse pad material onto the rotor. whenever i have the pads warm i try and use the brakes as little as possible, trying not to just leave them applied while im at a stop.
Old 04-17-2008, 04:34 PM
MUGEN_EG95's Avatar
Default Re: (zid)
yea the man drives pretty damn hard but he doesn't use his e-brakes much.
Old 04-17-2008, 05:15 PM
WhiteGSR95's Avatar
probably rotors. but could be the pads too. i once did the brakes on the dealers odyssee shuttle van.whenever i would brake it would vibrate like crazy. went away when they stoped being cheapos and got oem parts
Old 04-20-2008, 08:16 AM
tsdunay's Avatar
I had this same issue, i thought it was my rotors, but after I put new tires on my car, it got rid of 95% of the shaking.
Old 04-20-2008, 05:03 PM
walker941's Avatar
rotors are worked. got to replace them
Old 04-20-2008, 08:08 PM
knaira112387's Avatar
rotors..........................
Old 04-20-2008, 10:15 PM
DiMpL3s.'s Avatar
Default Re: (knaira112387)
it the rotors...
and if he did the brakes not to long ago with a fresh turn on the rotors he didn't brake them in good and probably got them to hot....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r3vmixman &raquo;</TD></TR><TR><TD CLASS="quote">, possibly an alignment problem too. If your toe is off you can feel vibration on the steering wheel.</TD></TR></TABLE>
dude ur alignment would have to be so far off!!!!
look guys if ur car shakes driving down the road with not aplying the brakes at all... its the balance or tire or rim problem...
if ur car shakes when u apply the brakes.. its ur rotors warped...
if ur car shakes when driving and shakes when stopping.... its both...
unless ur alignment is so facked up that ur steering wheel is upside down when trying to drive straight... shaking will never come from ur alignment...
i see 2many stupid people who come into my shop and say... i need a alingment my car is shaking
HondaEconoBox
11
10-29-2005 12:18 AM
nikolai.
11-23-2003 05:28 PM
riceball777
07-22-2003 03:49 PM
dRuNk-dRiVer
13
03-20-2003 06:19 PM
Rob :190:
04-16-2002 10:01 AM
Quick Reply: car shakes when brakes are applied!
