Busted Engine - Honda-Tech
Busted Engine
Old 09-25-2009, 09:55 PM   #1
spartian182's Avatar
Icon6 Busted Engine
So my brother has been borrowing my 97 civic for a while because his truck is a piece. To say the least, he knows absolutely nothing about cars so its safe to assume that he has done nothing for up-keep. So, as he is driving down the interstate today he blows a hole in the exhause side of the block roughly the size of of a pool ball.... I plan on fixing the car and at the same time want to play around with it. I've never pulled an engine much less done a complete rebuild so i thought it would be fun to strip the old block to the core and replace it. I know enough about my car to get by on a day to day basis and do numerous types of repairs but am in no way ex expert. maybe a novice..lol. so anyway the engine is a D16Y8. Nothing fancy and i don't really plan on going to crazy with the rebuild. Probably just going to stay close stock with maybe a few internal upgrades. My question would be if there is anything in specific that i really need to pay close attention to so i don't end up losing the whole engine completely.
spartian182 is offline   Reply With Quote
Old 09-25-2009, 10:08 PM   #2
dirtySOHC's's Avatar
Default Re: Busted Engine
Quote:
wrong forum.
buy a repair manual for your car. it will guide you during your engine overhaul. it's pretty straight forward but will be time consuming. remove motor, take off head on old motor, take off tranny, bolt tranny and head to new bottom end (assuming there is no damage to the head), drop motor back in and you're done. of course it's motor detailed than that but like i said the manual will guide you through it.
dirtySOHC's is offline   Reply With Quote
Old 09-25-2009, 10:17 PM   #3
I already have the and chilton manuals for both my cars. Im pretty familiar with the process and have been doing some research on engine swaps for some time now. I guess more specifically im concerned about disconnecting all of the fuel and A/C lines or anything that might go supernova on me when I start pulling screws and bolts.
Old 09-25-2009, 10:21 PM   #4
yea. sorry about that. had a little dislexic moment. just realized that said 2006.
Old 09-25-2009, 10:45 PM   #5
follow the steps to clear the fuel system/lines and you'll be fine. Never delt with AC so I can't help you. the most crucial part IMO is putting the head on to the new block and intalling the timing belt correctly...take your time and line everything up correctly. torque every bolt correctly and in the right sequence (headbolts). if you're researching then you're on the right track. nobody personally showed me how to swap/build motors...I learned everything by reading and trial and error.
Busted Engine spartian182 Honda Civic / Del Sol (1992 - 2000) 5 12-19-2011 10:45 AM
Road rage stories.. let's hear them tw1tch General Discussion and Debate 26 08-13-2010 05:26 AM
Few problems. 1992 Integra. Help needed, apply within. Fook_me_honda Acura Integra 4 04-26-2007 12:31 PM
My friend needs help with his car, he's about to junk a brand new car!!!!! jurenic Acura Integra 14 01-12-2005 07:17 AM
Performance Shop of Ill Repute. Buyers stay AWAY!!! Racer-X Honda CRX / EF Civic (1988 - 1991) 72 05-07-2001 01:41 PM
Tags
97, block, busted, civic
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
