power windows not working
I have a 06 civic ex. The drivers side window and passengers side rear window doesn't work at all. They quit working at the same. Fuses look good. Any suggestions. The other windows work fine.
thanks ahead of time
Re: power windows not working
I would check to see if its got any movement...(dies it make any noise or grinding when hit)
If not its likely a blown out motor...
And if so It could be a bad regulator...
You can get a replacement for cheap on eBay ($50) and its pretty easy to install...
Good Luck
Good Luck
When i hit the bottom to go down i can hear a click. I thought about it being a bad motor but they both quit working at the same time.
