Advantage/Disadvantage of vented disc brakes?? - Honda-Tech
Old 01-30-2007, 09:06 AM   #1
06 Habanero-NaVi's Avatar
Default Advantage/Disadvantage of vented disc brakes??
I don't know much about them...I guess I would do it more so for the look of them...but of course I know that Honda's brakes are gonna be the best...but how much of a difference would I notice in like stopping power...or braking distance?? Recommend or NOT Recommend??
06 Habanero-NaVi is offline   Reply With Quote
Old 01-30-2007, 09:10 AM   #2
cnyej1's Avatar
Default Re: Advantage/Disadvantage of vented disc brakes?? (06 Habanero-NaVi)
You mean cross drilled or slotted? If so the brakes are able to get rid of heat more quickly, thus reducing the feeling of brake fade under heavy braking conditions.
cnyej1 is offline   Reply With Quote
Old 01-30-2007, 09:55 AM   #3
IT GUY's Avatar
Get slotted, especially on a street car. Drilled is usually cheaper, but can mess with the structural integrity of the rotor (since it basically is full of holes)
Also, in addition to getting rid of heat; the holes or slots allow for expanding gases released by the pad material to escape. Getting rid of the gases lets the pad make complete contact with the rotor without a "pillow" of air (so to speak) between them.
Upgrade is worth it, especially with quality pads (not autozone) and SS brake lines.
I like all of my pedals to be more responsive, not just the throttle
Modified by IT GUY at 1:08 PM 1/30/2007
IT GUY is offline   Reply With Quote
Old 01-30-2007, 10:42 AM   #4
SYTFU Tommy.'s Avatar
Default Re: Advantage/Disadvantage of vented disc brakes?? (IT GUY)
i feel that there is no point in it. just asking for a cracked rotor FTL . blanks are the way to go on the street
SYTFU Tommy. is offline   Reply With Quote
Old 01-30-2007, 10:49 AM   #5
tone*def's Avatar
Default Re: Advantage/Disadvantage of vented disc brakes?? (SYTFU Tommy.)
I say if you go road racing alot or track(curcuits) it's worth getting em.~!!!
tone*def is offline   Reply With Quote
Old 01-30-2007, 11:06 AM   #6
bps2799's Avatar
Quote:
Honda's brakes aren't the best, but it is very easy to buy something worse. Brembo is always a good choice, as are Centric. If you must go slotted, just do the front rotors; the rears are already kinda thin and the need to "scrub" the pads with slots is minimal. There will be no noticeable performance benefit 90% of the time, but they may help in wet weather or if you've started to glaze the pads.
bps2799 is offline   Reply With Quote
Old 01-30-2007, 01:10 PM   #7
Nohawk's Avatar
I like all of my pedals to be more responsive, not just the throttle Modified by IT GUY at 1:08 PM 1/30/2007
Also, slotted rotors help keep dirt and grime off your pads. This helps your pads last longer and and give you better performance.
Nohawk is offline   Reply With Quote
Old 01-30-2007, 01:34 PM   #8
bps2799's Avatar
Default Re: Advantage/Disadvantage of vented disc brakes?? (Si 4 Life)
Quote:
It doesn't help the pads last longer, but rather it wears them sooner as it scrubs the surface of the pad. It MAY help performance if you've glazed the surface or it is wet.
Old 01-30-2007, 05:05 PM   #9
HondaF1Fanatic's Avatar
Blanks are the best except on the most extreme big brake and racing kits because they retain the most thermal mass to dissipate heat. If you want to improve cooling get rotors with directional vanes. Finally, if your pads are getting so hot that they are gassing you need to choose new pads or quit driving like a hooligan on the stock ones. Your fluid will also generally boil before your pads gas, especially if you are using the stock fluid.
Jon
HondaF1Fanatic is offline   Reply With Quote
PCI Spherical Rear Trailing Arm Bushing & Carbotech XP12 Brake Pads REVIEW 92integraVTECgsr Road Racing / Autocross & Time Attack 24 07-16-2012 05:36 PM
01-05 Civic 15x7 +13 tire size recommendation? tonee_ Wheel and Tire 3 03-11-2011 01:23 PM
Need Honda Accord Brake Pad Recommendations MilaniBlack Honda Accord (1990 - 2002) 4 11-08-2010 12:29 AM
aftermarket oil pump, w. pump, tensioner? hybrid24 All Motor / Naturally Aspirated 1 05-01-2010 06:14 PM
Need new brakes....info??? rikoshade Acura Integra 2 11-02-2002 10:32 PM
Tags
04, accord, advantage, advantages, brake, brakes, cross, disadvantage, disadvantages, disc, discs, disk, drilled, induction, rotors, slotted, vented
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
