2012 Civic Hybrid - 31,000 miles. Do I actually need a transmission fluid change?
Hi,
First post, so first off, hello to everyone and thank you in advance for any help I receive.
Onto my question: I know very little about cars. As the title says I'm currently driving a 2012 Civic Hybrid. I'm right around 31,000 miles and recently took my car in for scheduled maintenance as indicated by the cars display. I figured it was just time for an oil change as it was displaying oil life at 15%. The dealer said that it was time for an a transmission fluid change, but I know dealers are motivated to get you to spend money.
I'm a recent college grad who hasn't landed a "real job" yet so money's a little tight, though hopefully it won't be in the near future. My question is: Is this something that is actually crucial at this point? If not, around what mileage (I know this will depend on other factors as well, but on average) should I get it done?
TL;DR: 2012 Civic Hybrid at 31,000 miles. Dealer recommended a transmission fluid change. I know dealers often recommend services sooner than they are actually needed. Is this service really needed now, and if not now, when?
Re: 2012 Civic Hybrid - 31,000 miles. Do I actually need a transmission fluid change?
Get it done. The fluids should be done regularly. Did you buy the car new? Do you have a maintenance schedule? I am not a hybrid guy, but I get my oil changed on the minder's recommended intervals and transmission fluid once every 18 months.
It's easy to do. The dealer will remove the tranny drain bolt(plug).
drain out 2 1/2 qts(ish) (you can pour the old fluid into an old 5 qt oil jug, to see how much came out, but 2 1/2 qts is what it will be).
put the bolt back in and torque it to 29 ft/lbs
pour 2 1/2(ish) qts of clean honda automatic fluid in.
Dealer will charge you $120.
Each qt costs $8(ish).
You save $100, which you could put ($70) toward a 3/8" ratchet & socket (metric) set, jack stands, and a 3/8" torque wrench, at Harbor Freight or Northern Tool.
