2010 Honda Civic Transmission - Honda-Tech
Old 01-21-2012, 01:50 PM   #1
Default 2010 Honda Civic Transmission
Hi, I have a 2010 Honda Civic that has a problem with a shifting problem. Whenever I press on the gas, the car rev's but does not drive. After a little bit the transmission kicks in really hard into gear and then starts to drive. Same thing happens in reverse. The transmission takes a bit to kick into gear. The gears are basically lagging when they are supposed to shift. When they do shift, it feels like the transmission kicks the whole car. I have already replaced the transmission and the same problem is still there. What is wrong with the car? Anyone else have this problem?
mafiadogg is offline   Reply With Quote
Old 01-21-2012, 02:16 PM   #2
El Presidente
DaveSi677's Avatar
Default Re: 2010 Honda Civic Transmission
Is this an auto or manual?
DaveSi677 is offline   Reply With Quote
Old 01-21-2012, 09:17 PM   #3
its an automatic.
Old 01-23-2012, 07:58 AM   #4
bee guz's Avatar
If your fluid level is correct the transmission has some issues, possibly in the transmissions computer.
I would take it to a dealer and have it diagnosed asap, before you do more harm to it.
bee guz is offline   Reply With Quote
Old 01-23-2012, 10:21 AM   #5
There is enough transmission fluid. I'm also thinking that it might have something to do with the computer. The transmission is new and should not have problems like this.
Old 01-24-2012, 07:17 AM   #6
dtapia's Avatar
is their any codes stored or the D light flashing ?
dtapia is offline   Reply With Quote
Old 01-25-2012, 12:09 PM   #7
YES! The D light does flash! Can you tell me whats wrong?
Old 01-25-2012, 01:03 PM   #8
av911's Avatar
D flashing = Bring it in!!!
av911 is offline   Reply With Quote
Old 01-25-2012, 04:49 PM   #9
dtapia's Avatar
Quote:
then the system needs to be scanned. most likely a pressure switch.
Old 01-25-2012, 05:32 PM   #10
when ur car is under warranty u should always take it to them when they will do it for free. the D light flashing is usually a transmission failure sign. its kinda like a misfire from the engine the CEL flashes instead. it may drive, it may not, but its limping for sure. so the trans will be limping for this instance
apexi_rsx is offline   Reply With Quote
Old 02-05-2012, 08:12 PM   #11
The car is in a certified transmission shop. Currently, they have not found the exact problem with the car..
Old 02-17-2012, 12:24 PM   #12
sounds to me you need to add some tranny oil :D
koukou0o2 is offline   Reply With Quote
Auto transmission problems Thatboyslim Honda Prelude 0 10-02-2015 11:18 AM
1998 Honda civic lx tranny problem need help senko14 Honda Civic / Del Sol (1992 - 2000) 8 06-29-2012 01:26 PM
94 civic will start but not drive or enagage gears danbeck1992 Honda Civic / Del Sol (1992 - 2000) 2 02-25-2012 12:24 AM
97 prelude Auto Tranny issues menelaus22 Honda Prelude 19 12-02-2009 06:32 PM
Driving a 1996 Accord with "kick down" disabled anita33 Honda Accord (1990 - 2002) 1 02-07-2009 05:07 AM
Tags
2010, 2012, civic, drive, earbox, flashes, flashing, hard, honda, kicks, light, problems, reverse, tech, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
