2008 Honda Civic Compressor out - Honda-Tech
Old 05-07-2011, 12:49 PM   #1
Default 2008 Honda Civic Compressor out
HELP !!! My 2008 Civic A/c not working. When I turn on AC the dash lights come on. The Fan comes on but not the compressor. I have checked the fuses. Pressure on Low side was 120 psi. Is the compressor out or is there a control panel problem.
beavstew is offline   Reply With Quote
Old 05-08-2011, 08:22 AM   #2
instructor74's Avatar
Default Re: 2008 Honda Civic Compressor out
Are you out of your 3 year 36k bumper to bumper I would just take it in to the dealer and have it checked. If you are out of your bumper to bumper they might repair it as a good will fix since the car is still so new
instructor74 is offline   Reply With Quote
Old 05-14-2011, 07:59 PM   #3
Hi. Check A/C thermo switch first. It seems you A/C compressor is not engaging even though A/C system command to engage.
There will be 3 pin wire at right beside Alternator. unplug and connect multimeter(use ohm scale for continuity) on outer pins.If there is continuity, your thermo switch is ok.
Then you need field coil assembly. You need to remove A/C compressor to replace(not easy if you are not tech). It is kinda common problem for 2006-08 civic.
Charlies Auto is offline   Reply With Quote
Old 05-26-2011, 12:18 PM   #4
I have this same issue - just replace the AC compressor relay in the engine fuse box. Buy it fromthe dealer ($20) but it has to be the exact same one. Dont let them sell you one that jsut looks like it. It wont work.
I have had to do this 4 times on my 2006.
VinceC is offline   Reply With Quote
1998 Honda Civic LX A/C Compressor Always On phillyphan Honda Civic / Del Sol (1992 - 2000) 17 06-01-2014 05:25 PM
91 integra a/c problem ray on boost Acura Integra 1 07-08-2008 07:27 PM
Which AC compressor for 96 Civic LX Borgia Honda Civic / Del Sol (1992 - 2000) 0 04-03-2008 07:39 AM
Civic A/C Compressor Wanted AcuraTech23 Want to Buy 7 12-12-2007 02:16 PM
A/C compressor PphamEK Honda Civic / Del Sol (1992 - 2000) 1 07-25-2006 10:17 PM
Tags
07, 2006, 2008, ac, civic, compressor, fan, fixing, honda, low, psi, si, side, stopped, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
