2008 Civic LX SRS DTC code 2-7
The following driver side srs components were activated and replaced: side air-bag curtain, side air-bag (seat), seat belt tongue set, side impact sensor (rear). SRS module was reset and crash data removed. SRS warning light still came on. Reset SRS light, and it goes off, but comes back on. Jumped the 4 and 9 pin of the ODB-II connector and SRS warning light flashes 2-7. That is, I turn ignition to position 2, SRS light comes on for 6 sec, then off for 2, then flashes 2 long flashes, then a pause, then 7 short flashes. This sequence of 2 long 7 short then repeats. The SRS DTC tables I can find don't show a 2-7 code. Am I reading the SRS codes incorrectly? Or, do I need a specific SRS DTC table to get a description of the code? Thanks in advance.
Re: 2008 Civic LX SRS DTC code 2-7
I am having a similar problem on my 06. After my car went into a ditch, I had to replace drivers side airbags and module, but I still have this 2-7 code. I took it to the dealer a three times with no success(they told me to replace seat belt which i already have, nonetheless i did it again and nothing changed). I also replaced the module 3 times, in other words i have spent a fortune to get this fixed(i am now out of warranty). let me know if you found the solution.
last night i decided to check the resistance in all of my srs components and when i got to the buckle(in the seat) there was no resistance(it should have been about 2.0-2.2 ohm)!!! i cant believe my dealer couldn't tell me this. Be cautious of junk yard parts. blerim, thanks for the pm, i suppose you came to the same conclusion before i did. i wish i came across you earlier that way i wouldn't of had a need to take my car apart, to check it all. thanks anyway.
deanwashere
07-25-2018 04:28 AM
Reaccion
Honda Civic (2006 - 2015)
24
10-20-2017 11:26 AM
lv6l
Honda Civic (2001 - 2005)
10-27-2006 08:13 PM
