Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
After engine cleaner engine surging
Old 10-20-2010, 11:16 AM
tbonez's Avatar
Default After engine cleaner engine surging
I clean my engine everytime I wash my car. After I cleaned it this time the engine is surging and ticking. The surging immediatley quits when I turn on the air conditioning. Any ideas? I cleaned the engine the exact same way as I have for the past two years without issue...
Old 10-20-2010, 05:16 PM
NO MERCY!
RICO_'s Avatar
Default Re: After engine cleaner engine surging
Have you had a coolant changed recently?
Old 10-21-2010, 03:58 AM
na+b18c_hatch's Avatar
do you spray the engine bay with water?
Old 10-21-2010, 06:11 PM
bkindness's Avatar
yup, check the questions above first.
Old 12-07-2010, 09:44 AM
guinnessstout's Avatar
I also spray off my engine bay each time. I have found that using compressed air to blow the water out of the electrical connectors and around the oxygen sensors always helps to ensure that the water is not causing a problem in the long run.
oem_CD5
07-09-2006 06:28 AM
realmc
08-09-2005 09:20 PM
4doorex
11-30-2004 12:30 PM
SkylineGTR
02-05-2004 04:45 PM
Quick Reply: After engine cleaner engine surging
