2006 honda civic trunk lock switch - Honda-Tech
Old 10-17-2009, 07:25 PM   #1
New User
Default 2006 honda civic trunk lock switch
The trunk on my civic will not close anymore. I noticed that the tension spring in the switch/latch assembly was disconnected so I removed the cover and put the spring back on. With the spring back on the lock responds to the key or trunk lever by switching open. However, when I try to close the trunk it does not engage the switch when making contact with the striker. I moved the u-bar striking up as much as I could get it and it is still not making enough contact to engage the latch. When I push up on the latch with a pencil it does engage on the pencil.
Anyone ever ran into this and find a solution? Does the whole switch need to be pulled out and replaced?
skyseanie is offline   Reply With Quote
'97 EK Trunk wont lock ACinema Honda Civic / Del Sol (1992 - 2000) 3 08-07-2011 08:33 AM
2002 Civic Trunk Wont Stay Closed 116souljah Honda Civic (2001 - 2005) 2 06-01-2011 03:55 PM
2001 Honda Civic Trunk Latch Shaynepolevault Honda Civic (2001 - 2005) 8 01-20-2011 04:09 PM
2000 Civic EX Trunk Latch Issue D16SohcVtec Honda Civic / Del Sol (1992 - 2000) 1 11-23-2010 09:54 PM
Trunk Pop problems... 4doorex Audio / Security / Video 4 11-04-2004 07:25 AM
Tags
1990, 2002, 2006, 2009, accord, assembly, civic, honda, key, latch, lock, locked, open, spring, trunk
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
