Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
2006 Honda Civic SI Torque Specs
Old 10-26-2008, 06:31 AM
New User
Dimazz's Avatar
Default 2006 Honda Civic SI Torque Specs
Hello,
2006 Honda Civic SI Coupe
Could somebody with the service manual look up a couple of specs for me please. Or if somebody knows where to download and or reference the manual online a link would work too.
I need the torque specs for the FLCA to the subframe, both bushings. Brake caliper to knuckle. Lower ball joint to knuckle. Tierod to knuckle. Knuckle to strut. Wheel lug nuts.
All of this is for the front.
Thanks in advance!
Old 10-26-2008, 07:41 AM
Road House
FijiBlueFG2's Avatar
Default Re: 2006 Honda Civic SI Torque Specs (Dimazz)
The dealer will tell you it is about 139ft/tq
In reality, probably closer to 120ft/tq
Old 10-26-2008, 08:48 AM
New User
Dimazz's Avatar
Default Re: 2006 Honda Civic SI Torque Specs (FijiBlueFG2)
What is that spec for?
Old 10-26-2008, 09:24 AM
SIVIC 3's Avatar
^for the k20z3, i assume. thats what you asked about.
i put down 143 ft/lbs. but im i/h/e etc..
Old 10-26-2008, 10:38 AM
Nexx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimazz &raquo;</TD></TR><TR><TD CLASS="quote">
Old 10-26-2008, 10:55 AM
i-VTEC_DOHC's Avatar
i think for the lug nuts its around 70-80 i think?
Old 10-26-2008, 11:01 AM
SIVIC 3's Avatar
Default Re: (SIVIC 3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIVIC 3 &raquo;</TD></TR><TR><TD CLASS="quote">^for the k20z3, i assume. thats what you asked about.
i put down 143 ft/lbs. but im i/h/e etc.. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimazz &raquo;</TD></TR><TR><TD CLASS="quote">Hello,
Thanks in advance!</TD></TR></TABLE>
Old 10-26-2008, 01:16 PM
NO MERCY!
RICO_'s Avatar
Wheel lug nut specs are 80ft./lbs for all wheels. Not sure about the rest of the specs though.
My advice.....drive to a HOnda dealership and around back to the actual service shop entrance and see if you can speak to a technician directly. If they're cool enough they'll look it up for you on the spot.
Old 10-26-2008, 03:00 PM
Blk06Si's Avatar
Front side of the lower arm mounting bolt-61
Rear side of the lower arm mounting bolt-47
The flange bolt and the self-locking nuts from the lower arm-43
Caliper to knuckle-80
Info taken from Honda interactive network. Same source technicians use. Hope this helps.
drcain
09-06-2007 12:39 PM
DImages56
Suspension & Brakes
03-04-2007 05:12 PM
an2ny888
09-06-2006 07:41 AM
Tim2179
08-01-2006 05:39 PM
93CamaroLT1
05-31-2006 06:57 PM
Quick Reply: 2006 Honda Civic SI Torque Specs
