Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
09 honda civic si goes into gears but wont move.
Old 02-26-2014, 05:31 AM
nopain20's Avatar
Icon2 09 honda civic si goes into gears but wont move.
Okay I can put my car into all the gears but when giving it gas it wont move. The rpm rev up but haven't check to see if the Speedo move to or not. Could it be the axles or a bad clutch? It a 2009 honda civic si with 79,xxx mileage. Any help is appreciated.
Old 02-26-2014, 07:36 AM
DaveSi677's Avatar
Default Re: 09 honda civic si goes into gears but wont move.
It could be a variety of things...
Is there any pressure when you engage the clutch and try to find the friction point?
Old 02-26-2014, 12:10 PM
swain2894's Avatar
Can you stall your car? Just put it into a gear and let out the clutch and see if you can stall, if you can't your clutch is out.
Old 02-26-2014, 12:19 PM
DaveSi677's Avatar
Also could be cmc
Old 02-27-2014, 05:14 AM
nopain20's Avatar
Thank. Guss it time for a new clutch.
Old 02-27-2014, 08:44 AM
DaveSi677's Avatar
Get it checked out before assuming you need a new clutch... like i said it could be a variety of things related to the clutch.
Old 03-07-2014, 10:09 PM
tlarimer's Avatar
Broken shift cable boots will cause this
Old 03-08-2014, 10:55 AM
sstupid's Avatar
If it goes into every gear while motor is running, it is the clutch. Pure and simple. Mine went out on my '06 Si, at about that same mileage. I'm surprised you didn't notice issues before it got this bad, like slippage on the highway.
Old 03-15-2014, 06:24 AM
edselatlife's Avatar
This is a transmission problem man. I just suffered threw this same problem and my car is under warranty and honda doesn't wanna fix it. Get it fixed before your whole tranny goes down..
Old 03-16-2014, 03:31 AM
98ekb18c's Avatar
Sounds like its most likely a bad clutch. Are you sure you didn't break an axle/have one pop out of the tranny?
Old 03-16-2014, 01:08 PM
WhiteGSR95's Avatar
if you let out the clutch and the engine doesnt stall your clutch is done. if you are in an open space rev the hell out the engine pumping the clutch. it might crawl a bit. if your axle broke you would hear it. give everything a look but its most likely your clutch
FliiBoii
02-03-2012 07:50 AM
denisq6
10
10-12-2011 06:46 AM
moe2o4
Classic Hondas
02-06-2011 04:22 PM
moe2o4
Classic Hondas
02-06-2011 02:28 PM
Quick Reply: 09 honda civic si goes into gears but wont move.
