Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
08 Civic EX oil capacity
Old 04-27-2009, 11:59 AM
New User
B0tta's Avatar
Icon6 08 Civic EX oil capacity
I just changed the oil on my 08 Civic EX. 1.8 L engine. Drained the oil changed the filter. Refilled the crankcase with 4 Quarts of oil. Now when I check the oil with the dipstick it reads low just barely registering on the stick. Car is level, oil has had 1 hour to drain back into pan. New oil is clean, but I can read it. Could I have the wrong dipstick? Both my owners book and the service manual say 3.9 Quarts with filter.
Old 04-27-2009, 04:08 PM
pd0019's Avatar
Default Re: 08 Civic EX oil capacity
ive noticed that it is very hard to read the dipstick on the r18. try looking very close...it sounds like you did everything correctly
Old 04-27-2009, 05:10 PM
ekb16's Avatar
i think u should be good.. 4qts is how much i usually put at work
Old 04-28-2009, 03:29 AM
MWLW20's Avatar
is the car on a level surface?
Old 04-28-2009, 10:48 AM
Zeusone's Avatar
can you read?
Old 04-28-2009, 10:52 AM
MWLW20's Avatar
Originally Posted by Zeusone
can you read?
yes, I can read...I just looked over it quickly and missed that part.
Old 05-02-2009, 12:58 PM
IN VTEC's Avatar
The R18's take 4.2 to 4.3 qt's to put it at the top line.
Old 05-02-2009, 02:03 PM
av911's Avatar
Old 05-02-2009, 02:14 PM
IN VTEC's Avatar
Trust me, I work at a dealership and typically do 2 to 3 of these a day.
Unless you want to challenge the metering on our pumps, but I can do two things to clear that up. One, I can do a comparison against a calibrated standard. Then, I can run a series of samplings with that calibrated standard to describe the historical and predicted volumes that this pump will issue under the ambient conditions during this time of year for my location. I probably won't do that because I really don't care that much and I'm lazy as **** right now.
Old 05-02-2009, 02:45 PM
av911's Avatar
It ALWAYS takes 3.9-4.0 qts for me, every single time, I don't know what you're doing.
Old 05-02-2009, 05:40 PM
pd0019's Avatar
its 3.9...i dont know where you're getting your numbers from but you are wrong IN VTEC
Old 05-02-2009, 05:46 PM
K5^
Brand New
K5^'s Avatar
Since when did working at a dealership mean ****? Moreover, more often than not, dealership personnel have f ucked up something on my car which is why I gave up on them all together. So if you do work for a dealership, I wouldn't go on bragging about it because it doesn't carry much weight with people.
Old 05-21-2009, 11:53 AM
New User
B0tta's Avatar
Thanks for the info. You are the only one who knows what he is doing. I also found a person at the Honda parts counter who owns the same car as me. He also verified the capacity at 4.4 quarts
Old 05-21-2009, 01:27 PM
av911's Avatar
I guess following the owner's manual, service manual, and the fact I put 3.9-4 qts, which sits right at the top line of the dipstick is wrong....
Old 05-21-2009, 01:29 PM
K5^
Brand New
K5^'s Avatar
Obviously a tech at a Honda dealership is much more in the know than the engineers that designed every aspect of these cars. The owner's manual is clearly second protocol after the omnipotent techs.
Old 05-26-2009, 04:18 PM
safedriver's Avatar
I have a 08 SI.
I ended up putting 4.4 qts.
I have a 06 EX and I fill them till their dip stick indicates full.
Last edited by safedriver; 05-27-2009 at 05:22 PM. Reason: SI info decribed for EX sedan.
Old 05-26-2009, 07:25 PM
Nighthawk R18's Avatar
change oil, put 3.9, drive it, and stfu
if anything f's up i have the owners manual to back me up instead of the dipstick.
Old 05-26-2009, 08:42 PM
K5^
Brand New
K5^'s Avatar
Think with your dipstick Jimmy!
Old 05-27-2009, 10:19 AM
pd0019's Avatar
4.2-4.3 qts is what you put in an SI not an EX
azi90
Honda Civic (2001 - 2005)
07-31-2013 12:34 PM
TUR3Ovtec
08-15-2009 03:10 PM
square_1
07-30-2007 09:16 AM
tilhasbb
24
05-28-2007 12:11 PM
Iomega01
10-17-2005 06:57 PM
Quick Reply: 08 Civic EX oil capacity
