06 civic tensioner problem! - Honda-Tech
Old 04-11-2011, 06:36 PM   #1
Default 06 civic tensioner problem!
Ok so i have 1.8 civic coupe . That i was doing my serpentine belt so i pulled up on my tensioner and the belt came out fine. Then when going to put the new belt on my tensioner seens not to be puttin tension on the belt . Now i have alot of slack left i mean like a extra pully slack. So im lost and give up . What am i doing wrong? Ok before you guys tell me stuff that i already checked . The belt matched the length of the old one. Ok the car has ac so it is the right belt. Im lost. I even went on all data to see the belt routin and it matched the way i had it. Please any help would be apperciated
hondaon18's is offline   Reply With Quote
Old 04-15-2011, 07:25 PM   #2
Default Re: 06 civic tensioner problem!
...a extra pully of slack?
Get a repair manual and verify the path of the belt, over the pullys.
You can always use the book for torque specs.
safedriver is offline   Reply With Quote
Old 04-16-2011, 06:44 PM   #3
pd0019's Avatar
when you hold the tensioner to put the new belt on is it giving resistance? if not then your tensioner is bad...otherwise id say to recheck your routing even though you have already double checked it.
pd0019 is offline   Reply With Quote
Old 04-16-2011, 07:42 PM   #4
Chiovnidca's Avatar
You're probably wrapping it around the pulleys wrong. They changed the belt and routing of it on some models.
Chiovnidca is offline   Reply With Quote
Timing belt change procedural questions not replacing tensioner WaryDriver Honda Civic / Del Sol (1992 - 2000) 7 08-11-2015 07:19 PM
half inch of slack in timing belt ? bryanja7 Honda Civic / Del Sol (1992 - 2000) 7 09-26-2013 07:31 PM
HELP!!! B18 TIMING BELT REPLACEMENT msminty Engine Management and Tuning 11 08-28-2010 07:51 PM
Correct Method for Timing Belt Tension yosuthnmasa Honda Civic / Del Sol (1992 - 2000) 8 04-08-2008 08:29 AM
Tensioner access? Lost Type R Honda Civic / Del Sol (1992 - 2000) 9 11-10-2004 09:42 AM
Tags
06, 2006, accord, belt, changed, civic, gallery, guide, honda, hondatech, problem, slack, tensioner, tons, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
