06 civic hybrid. Can I install an amp and sub with the factory navigation system
1 Post
Ok I just bought a 2006 civic hybrid with the factory navigation. Can I install a aem with a small sub in this can and keep the factory navigation? Can u even install a small system in this car since it does not have an alternator? I'm not looks for anything crazy. Just a small amp with a small 10 inch sub.
Re: 06 civic hybrid. Can I install an amp and sub with the factory navigation system
Everything is still run off of a 12V system. Just run your power wire from the battery like you would normally do (the 12V battery, not the main battery pack). You can either ground to the body near the amp or run a ground to the battery.
1 Post
How about the factory navigation? Can I plug RCA wires from the amp to the factory navigation?
Only if the head unit has RCA outputs. I'm not positive but, I'm pretty sure you don't have RCA outputs. Pull the head unit and look. Personally, I wouldn't go with the extra cost of RCA's and the labor of running more wires when you can just get an amp with speaker level inputs and tap into one of the rear speakers.
All that being said, you still have to run power and ground from the battery and from an ignition activated circuit to the amp.
TheKamikazeSquirrel
Audio / Security / Video
07-07-2004 09:45 AM
XViEtBoiX
01-21-2004 05:36 PM
