***OFFICIAL Hondata FlashPro Thread*** - Page 3 - Honda-Tech
Old 11-08-2009, 11:01 PM   #51
Ben850's Avatar
Default Re: ***The One and Only Official Hondata FlashPro Thread***
very nice bro
Ben850 is offline   Reply With Quote
Old 11-09-2009, 05:06 AM   #52
Lady Reject
ladizzlee's Avatar
im saving for my damn flashpro. $695 is my goal :D
ladizzlee is offline   Reply With Quote
Old 11-09-2009, 06:10 AM   #53
Road House
FijiBlueFG2's Avatar
^Don't forget shipping
FijiBlueFG2 is offline   Reply With Quote
Old 11-09-2009, 10:53 AM   #54
Greg50Lt's Avatar
you can get them cheaper then 695 shipped.
Greg50Lt is offline   Reply With Quote
Old 11-10-2009, 07:53 PM   #55
does the lowered rpms for vtech engagement affect overall speed? 1/4 mile? or 0-60? and if so, by how much?
or is it just more hp earlier?
Mattgrimes is offline   Reply With Quote
Old 11-10-2009, 08:57 PM   #56
Ben850's Avatar
off the top of my head, more HP earlier should increase the rev speed and therefor reduce 1/4 and 0-60 times, correct?
Old 11-10-2009, 11:33 PM   #57
also, this may be a dumb question, but it seems from dyno charts that I never paid close attention to, but sort of, that honda tuned the car originally to have the most power exactly at the shift point from 8000 (6200 rpms or whatever it is). Since the vtech is changed to start at 4500 or whatever the person chooses, does this negatively affect the shift points? I would think hondata would only make changes to increase power/ acceleration. But it's just a speculation.. Anyone?
Old 11-16-2009, 08:46 AM   #58
dirtySOHC's's Avatar
1) VTEC
2) if tuned correctly the early vtec engagement has been known to increase mid range and overall power so yes this can affect 1/4 miles times.
Quote:
you got it
it can negatively affect it if the person tuning doesn't know what they're doing.
hondata is responsible for providing the flashpro....the results of using flashpro are a direct reflection of the user....not hondata.
dirtySOHC's is offline   Reply With Quote
Old 11-16-2009, 05:00 PM   #59
Kentagious's Avatar
Question...So i've got a buddy who I was talking to about Flash Pro and he was asking that if you could tune it don't u need a Wide Band O2 Sensor?
Kentagious is offline   Reply With Quote
Old 11-16-2009, 05:21 PM   #60
i-VTEC_DOHC's Avatar
^no.
i-VTEC_DOHC is offline   Reply With Quote
Old 11-16-2009, 08:45 PM   #61
Quote:
Originally Posted by i-VTEC_DOHC View Post
^no.
don't mislead the guy.
kentagious, you dont need a wide band but it would be highly recommended. tuning without that is like tuning in the blind.
Old 11-16-2009, 10:15 PM   #62
i didnt mislead him. i've only heard of those on boosted cars, not n/a with bolt ons. and since fp can datalog af ratios, i dont think its all too needed
Old 11-16-2009, 11:30 PM   #63
you need a wideband to tune either setup. you can't just change fuel and timing maps without reading AF ratios from a proper wideband.
where does FP get these readings from? are SI's equiped with stock wideband O2 sensors...I'm not sure. if so then you are correct and you don't need a wideband assuming the SI has stock wideband sensors.
either way you need a wideband for proper tuning.
Old 11-17-2009, 02:12 AM   #64
Kentagious's Avatar
Ok, but is it going to make a big difference if i'm running just bolt ons? I would think that would be the way to go when I buy my Super Charger...
Old 11-17-2009, 03:45 PM   #65
im guessing its getting its readings from the sensor. because on fp, it tells you your af ratio real-time. i can make a video to show it also.
Old 11-17-2009, 07:17 PM   #66
They have a factory wide band 02 sensor. But if you have FI it's nice to have a gauge in the car so you can see if it goes lean and then you can back off.
Aftermarket wideband sensors read better than the stock one down in the richer areas i.e. 10's and 11's. N/A cars never run as rich so the factory wideband is not best suited for reading turbo a/f's when in boost tho. When you buy a wideband gauge they usually come with a sensor. I thought I read somewhere that the factory wideband is only accurate down to the 12's but aftermarket one's will read 10-20 AFR
ajpturbopittsburgh is offline   Reply With Quote
Old 11-17-2009, 07:36 PM   #67
tnk
tnk's Avatar
so this would be the correct order with mods?
1. i/h/e
2. recalibrate with flashpro
3. tuner to fine tune
or a tuner isnt needed but highly recommended?
tnk is offline   Reply With Quote
Old 11-18-2009, 07:06 AM   #68
Quote:
1. i/h/e
you can tune yourself if you know what you're doing.
Old 11-24-2009, 06:42 AM   #69
Oracle of GDD
Ross's Avatar
Is Flashpro only worth it if you are going to upgrade i/h/e first?
Ross is online now   Reply With Quote
Old 11-24-2009, 03:48 PM   #70
its worth it if you're going to do any kind of tuning.
Old 11-24-2009, 08:13 PM   #71
Greg50Lt's Avatar
FP is worth it if you decided to upgrade anything that will alter the performance of the car. The factory tunes on the FP are fine but yes youll will yeild slightly higher gains with a custom tune.
Old 11-24-2009, 08:29 PM   #72
Oracle of GDD
Ross's Avatar
I may be an Si owner soon; wanted to get a feel for what's out there these days.
I want to eventually raise the performance from stock form, but not change the overall driving experience that much. I still have a bad taste in my mouth from getting hassled all the time by cops and haters when I had my ITR, so I'm not sure I want to go the "louder" route...just a little racier.
Old 11-24-2009, 08:33 PM   #73
Greg50Lt's Avatar
well this gen of honda can run no cats at all with header and catback and remain very quiet and produce great numbers.
If you are to changeing the performance and you get it tuned or use a base tune from the FP you will greatly increase the fun and enjoyablilty in driving your car.
Old 11-24-2009, 09:13 PM   #74
Oracle of GDD
Ross's Avatar
Let's just say someone were to use the FP on a totally stock Si motor, no mods of any kind and using the base tune. What could you realistically expect?
Old 11-24-2009, 09:44 PM   #75
Ben850's Avatar
you'd atleast be able to change the i-vtec crossover and what you can rev to with the clutch pressed in.
Further testing with the 2007-2011 Acura RDX platform, K23A1 (DYNO) D-Rob Forced Induction 24 12-09-2015 10:46 AM
NEW: Hondata FlashPro Support for Acura RDX mtber Engine Management and Tuning 3 09-04-2013 12:26 PM
Hondata S100 S300 K-Pro FlashPro Heatshield Gaskets Map sensors Boost Solenoid Repair FullThrottleNYC Performance 55 01-18-2012 07:00 AM
HONDATA FLASH_PRO 4 SALE yung_gsr210 For Sale 0 10-06-2011 04:21 PM
hondata Flashpro group buy Greg50Lt Honda Civic (2006 - 2015) 72 01-07-2010 06:29 PM
Tags
accessport, control, driving, flash, flashpro, honda, hondata, hondatech, idle, impressions, launch, pro, s2000, set, si
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
